hesitation while driving
Old Nov 26, 2010 | 06:51 PM
loveless41908's Avatar
loveless41908
ive been driving my 85 f150 for awhile and have always had a problem with a sputter or hesitation while at cruising speed. ive removed the head cleaned everything and replaced all gaskets so im pretty much positive that there is no air leaks. im convinced that the problem is in the carb, which ive gone through before and installed a rebuild kit. im tempted to install a 2 barrel carb with an adaptor ive found. however ive read that my problem could be the ignition system. ive bypassed a lot of emissions on this truck and it makes sense that the ignition may be at fault. so which is the better start point, carburetion or ignition. ive heard of swapping in a duraspark ignition, not sure where to go. im really impressed with the power of the six, but as ive mentioned before i have a rebuilt 302 ready to go. anybody have any suggestions?
Old Nov 26, 2010 | 08:30 PM
Franklin2's Avatar
Franklin2
You have a six cylinder? Do you have a computer? Does your distributor have the ignition module mounted on the side with no vacuum lines going to the dist?
Old Nov 26, 2010 | 10:34 PM
ctubutis's Avatar
ctubutis
Welcome to FTE, lots of good info out here!
The 6-banger has more torque than the 302 and is a better truck engine IMHO, I'd suggest a
351W if you're wanting to swap engines.
Old Nov 28, 2010 | 04:31 PM
loveless41908
yes, franklin2, the distributor has the electronic module attached to the side
Old Nov 28, 2010 | 05:46 PM
84fordor's Avatar
84fordor
If you want to keep the six, than I would recommend swapping in a duraspark, or MSD setup, seeing as how there have already been some alterations to the stock system, especially since you are running the newer computer controlled ignition.
However, it could be something as simple as a funky egr issue.
Just my two cents
Old Nov 28, 2010 | 08:32 PM
Franklin2's Avatar
Franklin2
You need to do something with the ignition system as was mentioned. Your timing is going to be out of wack along with everything else since it was all computer controlled. It all depends on how much stuff you have taken off the engine. The computer can't work right if you take some of that stuff off.
Old Nov 29, 2010 | 09:26 PM
loveless41908
i think im going to go with the ignition swap, msd would be nice but ill probably try and find an old parts truck somewhere that i could rob an old ignition from. ill probably try going through the carb again also. i remember trying to remove the little module from the passenger sife inner fender, it has a vacuum line and a wire connector going to it. anyway i tried to run the truck without it and the timing advance was way off, couldnt get it set correctly without reconnecting the module. also i removed the already non functioning egr valve and capped it off.
Old Nov 29, 2010 | 10:39 PM
Franklin2's Avatar
Franklin2
You should get a older carb also. The one you are messing with now is electronic. Since you are ditching everything else, you should go all the way.
Old Dec 1, 2010 | 08:54 AM
84fordor's Avatar
84fordor
Good point, I'll second that.
Old Dec 2, 2010 | 08:43 PM
loveless41908
was just digging through my junk parts pile and found a couple 2bbl carbs that i forgot i had. both were off of a 302 and i belive that i could adapt one of those to my 300. im curious how to attach the throttle cable though, anyone had any experience with this particular swap?
Old Dec 5, 2010 | 05:23 PM
84fordor's Avatar
84fordor
I have done it with the 2.3 four bangers, and just made my own custom bracket out of the original and stuff laying around.
rbofenkamp
1997 - 2003 F150
Aug 25, 2015 10:48 PM
52flatheadf1
Jul 13, 2015 08:57 AM
quakerj
Apr 17, 2014 08:17 PM
Quinnbristow
1978 - 1996 Big Bronco
Sep 8, 2013 05:26 PM
quakerj
16
Aug 31, 2013 08:06 AM
