Transmission
Old Nov 6, 1999 | 08:22 PM
jp's Avatar
jp
Transmission
Has anyone experienced a consistantly rough downshift to first gear when slowing to a stop. The truck has the EB tow package...has a 5.4L and is a '99.
Old Nov 23, 1999 | 06:57 PM
James Tsai
Guest
Posts: n/a
Transmission
We had the same problem with our 97. It would clunk in 1 and 2 gears upon stopping. As well it would exhibit 'shift flaring', over-reving (it sounds like the torque converter will not engage).
We had a TSB 980920 performed (something to do with cross leakage in the transmission).
Then, two months later, the entire transmission was replaced.
Make sure you have it recorded by the dealer, so when your Expy is out of warranty, you have proof it occured during the warranty period. Keep good records.
Feel free to contact me: babytren@sprint.ca
Old Nov 24, 1999 | 09:52 AM
Scott's Avatar
Scott
Transmission
Is there any way to get a copy of the technical service bullitin that deals with this transmission problem.
Thanks
Scott
Old Dec 20, 1999 | 10:49 PM
Ken Rosales
Guest
Posts: n/a
Transmission
Old Apr 2, 2008 | 02:08 AM
danquin1's Avatar
danquin1
I have a 2000 expy, EB 5.4. 120K had the tranny flushed last time at 80K. should I have the tranny flushed again, or drain the pan and change the filter. The tech at the dealer said that flushing is all I need to do, since the filter is really a metal screen and flushing cleans that out as well, draining and changing the filter is not needed. any help would go a long way
Old Apr 2, 2008 | 06:45 AM
buzzard's Avatar
buzzard
Call me old fashioned, but I like to replace the filter when performing any fluid change where one is involved.
Old Apr 2, 2008 | 05:35 PM
Jugger's Avatar
Jugger
that whole flushing technique makes me nervous.....
Old Apr 2, 2008 | 05:43 PM
dr cabela's Avatar
dr cabela
every mech ive talked to says that flushing is terrible for your trans
the only good way is to drop the pan... change the filter/fluid
Old Apr 3, 2008 | 01:19 AM
danquin1's Avatar
danquin1
but by changing just the filter and dropping the pan, you only get out about 3/4 quarts, is that enought? do you really consider that an Trans oil change?
Old Apr 3, 2008 | 10:19 AM
buzzard's Avatar
buzzard
Drain the torque converter too and you'll need 16 or 17 quarts to refill....at least on a 4r100.
hermannm2
2009 - 2014 F150
Jul 16, 2016 12:51 AM
mustang_309
Nov 14, 2014 10:43 AM
fastball
2009 - 2014 F150
16
Mar 31, 2009 04:54 PM
joewaldner
34
Mar 4, 2008 08:13 AM
