simple request i think
Old Nov 25, 2010 | 06:17 PM
Hitokori's Avatar
Hitokori
well ive read threw about 8 million rabs threads
so i was wondering if someone could take some pictures of the wire i have to ground to get codes or what ever
both lights are on....i want them off
ive bled the entire system with clean fluid a while back when i change the driverside caliper and brake hose...
i also checked the sensor in the rear end and cleaned it up :P no to dirty to have 131,000 miles on her
88 f150 5.0 2wd c6
if u need more info let me know
Old Nov 25, 2010 | 07:21 PM
Muddy Truck's Avatar
Muddy Truck
The first picture is what it looks like on my 1990 F150 5.0 EFI. The second pic shows where it's located. You find it in this thin black box behind the air filter. It will be plugged into the bottom, you pull it out, connect it to your scanner and begin the procedure.
-Doug
Old Nov 25, 2010 | 07:40 PM
danr1's Avatar
danr1
The RABS 1 test connector is forward of the E brake pedal, two matting halves one with a black/orange wire connected to it, that is the wire you want to ground for 1 to 2 seconds after unplugging the connectors from each other.
RABS 1 does not store codes after key is turned off, must trigger test while light is on before turning off key.
Doesn't look like you'd need to remove the cowl panel to see it.
Old Nov 25, 2010 | 07:50 PM
Muddy Truck
My Bad, I didn't read your post clear enough and took a picture of the computer test unit.
Old Nov 25, 2010 | 07:51 PM
Hitokori's Avatar
Hitokori
k thnx and thank u too muddy truck ;-P even tho im not scanning for engine trouble codes
Old Nov 26, 2010 | 06:20 AM
EPNCSU2006's Avatar
EPNCSU2006
If both the RABS and Brake warning lights are on, double check that there is a good connection at the fluid level switch on the master cylinder.
Old Nov 26, 2010 | 07:40 AM
TexasGuy001's Avatar
TexasGuy001
If both the lights are on, can't you still pull trouble codes? I would try that anyway.
Old Nov 26, 2010 | 08:42 AM
Hitokori's Avatar
Hitokori
k gentlemen ill check the connector at the MC :-\
then ill check for codes...
Hussie
May 9, 2016 09:51 PM
tjbradney
Jul 27, 2015 10:30 PM
apachetech
Jul 17, 2015 01:19 PM
avi
Aug 4, 2007 07:46 AM
