Clutch Bleeding
Old Nov 25, 2010 | 11:32 AM
my1965f100's Avatar
my1965f100
Clutch Bleeding
When i am bleeding the clutch slave cylinder when i pump the pedal, hold it to the floor, loosen the bleeder screw, let air out, and retighten the screw the clutch pedal stays at the floor.
Old Nov 25, 2010 | 01:06 PM
Kapusta's Avatar
Kapusta
Just means there's a lot of air in it. Best thing is to make a power bleeder from a garden sprayer. The only thing you need to pump then is the sprayer. Bleeding is then done the same way as you normally would.
Old Nov 25, 2010 | 01:43 PM
my1965f100's Avatar
my1965f100
k ill try that thanks
Old Nov 25, 2010 | 02:41 PM
Lazy K's Avatar
Lazy K
Bleeding a Concentric Hydraulic Clutch Set-up .: Articles Also have a read here from Step 4.
Old Nov 25, 2010 | 03:37 PM
my1965f100's Avatar
my1965f100
thanks it worked as i was drivin it down the driveway and hit the brake the front brake like burst and we had the back brakes sealed off cause they were leaking thank god the steering didnt give out or i would have been in my neighbors pond
templars
1983 - 2012 Ranger & B-Series
Sep 14, 2019 07:42 PM
DSparksF250
Nov 7, 2016 11:06 AM
nacra88
May 15, 2016 06:06 PM
Countryboi
Mar 14, 2016 08:27 PM
maxride
Oct 1, 2015 07:00 AM
