Odd sound under load
Old Oct 27, 2009 | 08:54 PM
allis327's Avatar
allis327
I have a 91 f150 4.9 5 speed. Under load it makes a wooshing sound like an exhaust leak, but it stops when i shift up a gear and starts again about ten seconds under load again. Odd part is that it does not do this all the time. seems like a valve opening and closing any ideas. Also i need a new shifter boot where do I find one thanks
Old Oct 27, 2009 | 09:31 PM
BigSix1's Avatar
BigSix1
I think my '88 F-150 did this. Try experimenting with the fan speed of your heater blower. If you have a vacuum leak, the blend door of the heater box can change position, when your vacuum level changes, due to different throttle positions (i.e., under load) and can redirect air to either the defrost or floor or some combination, which can make a noticeable change in the in-cab sounds.
IOW, if you do hear it with the fan on High, and don't with it off, then that's what it is.
Just one possibility to explore--good luck.
Big Six
Old Oct 28, 2009 | 01:08 AM
TexasGuy001's Avatar
TexasGuy001
That almost sounds like pinging.
You definitely do not want that. It maybe be that your truck needs a tune up. Try running mid grade or supreme fuel for a tank full and see if it goes away.
Old Oct 28, 2009 | 02:00 AM
93 mix 'n match's Avatar
93 mix 'n match
mine did that also, i though it was something in the vacuum system.
as for the shift boot, the OE one was alot. i think over $150. so i picked up some hot rod one from autozone for $15 and put it in. it worked, looked OK up close, better from a distance.
this is the first fit. after this i took it off, made it level, polished it up and put it all back.
Old Nov 25, 2010 | 04:17 PM
allis327's Avatar
allis327
I figured the noise out. My cats were broken and occationaly blocking the outlet. More power now, I have a short comute so I never really get into the gas.
akamacgyver
Jul 27, 2012 11:42 AM
Explodin' Bryan
Aug 6, 2010 11:45 AM
AlaskanEx
Apr 11, 2010 08:19 PM
skswayze
Feb 28, 2010 01:49 PM
mcdavidson
Nov 7, 2006 04:02 PM
