Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Power steering
Old Nov 25, 2010 | 10:59 AM
imgoin's Avatar
imgoin
Power steering
Happy Thanksgiving.
Hello all, I am new to the forum but owner of Fords since I was 15 years old.
My 17 year old son ran across a 1986 F700 with the 8.2 DD allison trans.
The truck is a retired Dallas area rapid transit tow truck minus the tow boom. It has been thru 3 or 4 previous owners before he bought it this last summer. Needless to say the truck has had personal flare added by all previous.
He was excited to get it for $800. Previous owner had warned us that his helper had accidently put power steering fluid in the brakes, but no worry he had a local mechanic flush the lines.
Now the problems arise.
We noticed the leaks on the drive getting bigger. So we checked it out yesterday.
The last owner has put DOT 3 brake fluid in the power steering resivoir and the seals have started to disenegrate. What little dot3 was left in the system we tried to drain. put in P/S fluid and walla it leaked out over night.
I have looked on line for seal kits for the steering gear box and steering pump. I found the pump seals but not the gear box seals.
I'm planning replacing the hoses as well.
Question is does anyone know where a seal kit for the steering box can be had? Or is this an item that has to be remanufacured?
Thanks for any input.
Noel.
Old Nov 25, 2010 | 05:52 PM
jpr38057's Avatar
jpr38057
I'm not sure where you are but if you have a Truck Pro around they might be able to help. You might check with your local NAPA store also. I think it is a Ross gear.
Old Nov 25, 2010 | 08:04 PM
imgoin's Avatar
imgoin
Thanks for the reply.
We are in North Texas and there is a Napa in Denton. I will check there tomorow.
formercz
Oct 30, 2016 07:44 AM
whale15
1983 - 2012 Ranger & B-Series
Feb 22, 2016 11:23 AM
carver94f350
N. California Chapter
Oct 21, 2015 02:29 PM
Thumper19
21
Sep 1, 2012 03:01 PM
fzeed
Jun 21, 2009 11:58 PM
