Need help with pricing - selling
I'm in a bit of a financial bind, and I need to sell the 94. I have two options in selling. So I need some help.
First here's what's been done to it in the last 3 years to it.
Full brake system rebuild:
Brake Master Cylinder,
Front Calipers,
Front Brake Pads,
Brake lines (swapped over to SS lines when I did the RSK),
RAB Sensor,
Rear Brake Drum Cylinders,
Rear Brake Pads,
Flushed Brake Fluid,
Speed Bleeders
New 3G alternator - old one caught fire causing this, and as a result - New Radiator hoses, new wiring, new belt.
New Power Steering Pump and Reservoir - AGR Performance
New Steering Gearbox - AGR Performance
New Steering linkage
Rebuilt Transmission E40D
PMF 3.5" Reverse Shackle Kit up front
Super Duty Leafs all around
PMF 5" rear lift blocks
Billstein 5100 Series Shocks all around
New Energy Suspension Bushings
New PMF Adjustable Panhard Bar
New PMF Drop Panhard Bracket
New Pro Comp Drop Pitman Arm
New Crown Stainless Steel Braided Brake lines
New A/C condenser
New A/C lines
Banks Power Pack - Includes: Ram Air Intake, K&N Air Filter, Banks Exhaust Tube Headers, 3" Stainless Exhaust, Magnaflow Muffler, 4" Banks Exhaust tip
Stage 8 Stainless Steel Header Bolts (won't back out)
New Bosch O2 Sensor
New EGR Tubes
Oil Cooler Bypass: Removed the oil filter adapter from the block, removed the oil cooler box, added a new radiator hose to go from the radiator to the block bypassing the box that's no longer there.
Summit Dual Oil Filter Remote Location Kit (adds 2 oil filters and re locates them off the block)
Pro Comp 33" AT Tires
Gear Wheels (I have no idea what kind I got them off craigslist when i bought the truck for the tires they had on them for $150)
Rear Differential Fluid Change
New Motorcraft Fuel Filter
New Motorcraft Ignition Coil
New Thermostat
New Distributor
New MSD Ignition Coil Cap and Rotor
New Motorcraft Ignition Control Module
New TPS Sensor
New EGR Valve and Sensor
New Skyjacker Dual Steering Stabilizer
New Front and Rear Tank Fuel Pumps and sending units
Done During Rebuild:
Machined OEM heads
Valve seals
New Gates Water Pump
New Water Pump Backing Plate
New Cloyes Timing Gear and Chain Set
New Timing Cover
New Harmonic Balancer
New Motorcraft Spark Plugs
New Ford Racing 9mm Spark Plug wires
New Gates Belts (there are 2)
New Edlebrock Head Bolts
New ARP Component bolt kit (this is basically the set of bolts that covers about everything around the motor, throttle body, water pump, timing cover, alternator, etc)
New Gaskets, head gaskets, head cover gaskets, water pump, timing cover, oil seal, throttle body, etc.
New Motorcraft Oil Filters (2 for dual Filter kit)
New PCV Valve
New Temperature Switch
New Temperature Sensor
New IAC Valve
New Air Temperature sensor
New Idle Air Control Valve
New Hoses
New Vacuum Lines
New Saginaw Power Steering Pump (replaced the AGR Performance Noisy PSP I put on when I got the Gearbox)
New Transmission Filter
Full Transmission fluid flush and replacement
Rear Differential Fluid change
New Battery
New Battery Positive, and all grounds wire replacement
New Radiator
New Flex-A-Lite Fan
Full Fluid Flush and Replacement
A/C Recharged
Cleaned intake
Cleaned throttle body
Rebuilt Fuel Injectors - using Mr. Injector parts
Here is my Facebook Page for the Rebuild. (well it wouldn't load - it's Ford Beast-350 on Facebook) I plan to put the pictures up on here in a thread I just haven't had a chance to yet. I will get some pictures of it tonight to put on this post so it will help. I thought I had some on Photobucket but I don't have any good ones and the one I took of my phone must have gotten erased by accident.
So here are my options. As it sits right now, It has the White with Grey middle strip two tone paint (you can see it in my avatar pic). The grey is bad though, it's got some red blotches coming through it, I'm not sure what it is , but it's bad. Very noticeable. It also has a bent up front bumper from a small accident I was in. NO damage other than the bumper itself. Even the brackets are fine.
Option 1 - Put it up for sale the way it sits and let the next owner worry about the bumper and paint
Option 2 - I had planned on plasti-dipping the whole truck black, getting a new bumper, and also tinting the windows. Put it up fro sale after doing all of that extra work.
Which option would bring me more money? Which brings me to the next question. What should I list for taking into account each option?
Thanks guys, i really appreciate any help you can give.
Once I do that then I'll list it. Thanks for your response.
Jim
