Hello I have a 2000 super duty 4X4 XLT 5.4 and i have noticed that when braking hard or just braking in general it pulls to the right a little and really pulls if you smash the brake. Any help is much appreciated:
Little different view here. I have seen this when the power steering is the problem. As the pump is going out it will pull hard to one side and only when braking. I would start at the brakes also but my next stop would be the pump.
According to Ford service disks, also check wheel alignment and steering gear valve. Steering gear valve is easy check, Rotate tires and see if the pull direction changes.
OP has the 5.4, not the diesel... no hydroboost, so the systems aren't tied together...
I agree most likely it is a sticking slide pin... easy to check, and cheap to fix so start there!
