Sponsored by: Real Truck
torqueshift trans fluid
Old Nov 26, 2010 | 10:15 AM
LMS Residential's Avatar
LMS Residential
Ford Special Service Message 21114
MESSAGE TITLE: REPLACEMENT TRANSMISSION FLUID FOR SERVICING TORQSHIFT TRANSMISSIONS
APPLICABLE VEHICLES :
2003 - 2005 TRUCK : 00126 EXCURSION
2003 - 2008 TRUCK : 00028 F-SERIES
2004 - 2008 TRUCK : 00016 E-SERIES
2006 - 2008 TRUCK : 00175 F-SERIES MOTORHOME
2006 - 2008 HEAVY TRUCK : 00168 LOW CAB FORWARD
OASIS MESSAGE :
ALL 2003-2008 F-SUPER DUTY, 2003-2005 EXCURSION, 2004-2008 E-SERIES AND
2006-2008 LCF VEHICLES EQUIPPED WITH A TORQSHIFT AUTOMATIC TRANSMISSIONS SHOULD
BE SERVICED WITH MERCON LV AUTOMATIC TRANSMISSION FLUID IN PLACE OF MERCON SP.
THIS INCLUDES TOP OFF AS WELL AS FLUID REPLACEMENT. MIXING MERCON LV AND MERCON
SP IN THE TORQSHIFT TRANSMISSION IS ACCEPTABLE. USE MERCON LV TRANSMISSION FLUID
TO SERVICE VEHICLES EQUIPPED WITH TORQSHIFT TRANSMISSIONS. WHEN ADDING OR
REPLACING TRANSMISSION FLUID IN A VEHICLE EQUIPPED WITH A TORQSHIFT
TRANSMISSION, USE MERCON LV TRANSMISSION FLUID .
This is the full 21114. I hope some of you are wrong because I just got mine done using the LV per the bulletin referenced above. So far, havent really noticed a difference one way or another, trans has always shifted fine.....so far.
Subscribed.
Old Nov 26, 2010 | 10:46 AM
Furian's Avatar
Furian
You Keep What You Kill
I just had my ATF flushed and used Mercon SP. I paid $4.91 per quart with free shipping. I can't find any Mercon LV for sale on Google.
Ryder
Old Nov 26, 2010 | 11:01 AM
LMS Residential
Ryder
Went to about 6 places here before I found someone willing to order a couple of cases of the LV here. Its local but if it helps anyone it was Lee Auto Parts Franklin Park IL. They got it overnight and it was, surprisingly, 3.99 a qt and the guy at the counter was cool enough to give me a dealer discount which brought it to 3.60. He had recently ordered a bunch for the Leyden Township utility vehicles and was the 1st guy able/willing to find it. My dealer/friend was still pitching the SP until I showed him the bulletin. Don't know if they've switched over.
Old Nov 26, 2010 | 12:19 PM
i eat hybrids's Avatar
i eat hybrids
wow that aint bad.. I thought it was gonna be like 10 or 15 a quart
Old Nov 26, 2010 | 12:24 PM
slowmans's Avatar
slowmans
Originally Posted by lostru
Just picked up two cases at the Dealer not to long ago. I asked him about the replacement for SP. I was told that Ford has changed their mind on LV's ability to replace SP and have now gone back to recommending the SP. Correct or not? I trust the guy and everyone can be wrong. As far as a Torque Flight transmission. Is it a four or 5 speed?
If your refering to the tourqshift transmission thats in our super duties, its actually a 6 speed but only uses 5 of the gears depending on transmissin temperature.
Old Nov 26, 2010 | 12:34 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
The LV is used in more ford trannies while I believe the SP is only used in the torqshift. Hence why the LV is cheaper than the SP (higher volume production).
Old Nov 26, 2010 | 12:38 PM
i eat hybrids
How many quarts does the TS take??
Old Nov 26, 2010 | 04:02 PM
slowmans's Avatar
slowmans
if your just draining the pan I belive its 7.5 to 8, the whole system holds 17 I believe...
Old Nov 26, 2010 | 09:23 PM
i eat hybrids
ok sounds good. I bought 19 qts today
Old Nov 27, 2010 | 08:55 AM
slowmans's Avatar
slowmans
Originally Posted by senix
It is a 6 speed. Sometimes does not use all 6, depending on circumstances.
Nice edit!
Old Nov 27, 2010 | 09:17 AM
senix's Avatar
senix
Originally Posted by slowmans
Nice edit!
Yup...I always get that mixed up because of only using 5 and they other just takes a break.
04scurs
Apr 5, 2013 09:19 PM
98SurplusExpy
Apr 3, 2010 07:55 AM
fhipper
Nov 17, 2009 01:21 AM
Uzumati
Jul 29, 2006 10:51 PM
ruby2
Oil & Lubrication
Mar 14, 2003 09:16 PM
