ELC
Old Nov 23, 2010 | 02:38 PM
RobertJohn's Avatar
RobertJohn
Question ELC
I've got the red extended life coolant in my PSD, I think it is Rotella.
I need to add a little but can't find the red elc close.
Is it safe or will it mess up my ELC if I add another brand ?
I don't want to add the green, I'd rather add distilled water.
Any suggestions or hints or tips ?
Thanks
Old Nov 23, 2010 | 03:50 PM
clux's Avatar
clux
You'll be fine as long as it's an OAT ELC, but don't mix chemistries.
Old Nov 23, 2010 | 04:41 PM
Stewart_H's Avatar
Stewart_H
I was in SoCal one weekend a few years back when I realized my degas bottle (radiator reservoir) was almost completely empty, about an inch or so from the very bottom.
I went the rest of the weekend before driving home the 9+ hours and I was good to go. I just monitored the level making sure the res never completely went empty and when I got home, I filled it back up with ELC.
How low is your res?
Stewart
PS - X2 what Clux said.
Old Nov 23, 2010 | 07:01 PM
RobertJohn's Avatar
RobertJohn
Mine is only down about 4 in...
I've filled it up several times but it always drops about 2 in and holds there. So I just leave it there but now it's down about 4 in... When I get back, I'll run it up on the ramps and see if I can find a leak or something.
Thanks for all the info..
Old Nov 23, 2010 | 07:21 PM
spdmpo's Avatar
spdmpo
LOL, my dad and I were discussing this the other day. No matter how many times we fill it, it still drops an inch or two. So we both just stopped filling it, and it's never dropped lower. Weird.
Old Nov 23, 2010 | 08:04 PM
guitarpicr's Avatar
guitarpicr
Could probably get by w/ the distilled as long as the temps aren't below freezing. Can always drain a little later & add some more elc
Old Nov 23, 2010 | 10:32 PM
ScaldedDog's Avatar
ScaldedDog
How do you test whether your ELC mix is right, anyway? Would plain ol' antifreeze test devices from a parts store work?
Mark
Old Nov 23, 2010 | 11:15 PM
Vitaliykit's Avatar
Vitaliykit
As long as you can see some in reservoir, I wouldn't bother, it would not overheat. Just find what you like and add then, (but I ran all kind of brands and mixes in my 99 and not one problem and it has way over 400k.)
Old Nov 24, 2010 | 12:04 AM
Stewart_H's Avatar
Stewart_H
Add enough of the "find what you like" that isn't an OAT ELC and you lose the benefits of the ELC. You just can't do that to a rig that's been backflushed and filled with a heavy duty Extended Life Coolant and you do a disservice even suggesting that to the OP.
Stewart
Old Nov 24, 2010 | 12:35 AM
Vitaliykit's Avatar
Vitaliykit
sorry, i didn,t make myself clear, by saying what you like I meant - red extended life coolant, that's why I started by saying that "As long as you can see some in reservoir, I wouldn't bother" - meaning not to be in the hurry and add just anything, but I made it confusing by the way I ended it. Sorry. Hope this helps.
Old Nov 24, 2010 | 01:00 AM
Stewart_H's Avatar
Stewart_H
Yeah, it absolutely does!
Stewart
Old Nov 24, 2010 | 07:56 AM
SpringerPop's Avatar
SpringerPop
Mark
Depends on what you mean by "plain ol' antifreeze test devices".
Red ELC is still ethelene glycol, it's the additive package that's different.
That means the specific gravity will be virtually the same as conventional coolants, and the hydrometer-type testers (for freezing point) will work just fine.
However, the specialized test strips for testing the previously-added SCA's will likely not indicate properly.
If you've done a thorough flush of the system when installing the red, you won't ever need those test strips again, anyway.
Pop
Old Nov 24, 2010 | 03:44 PM
ScaldedDog's Avatar
ScaldedDog
That's exactly the answer I was looking for. Thanks!!!
I'm putting one of Clay's water pumps in soon, and need to top off the bottle when that's done. I'd like to know whether I should top it off with CAT ELC, distilled water, or a mixture, and this will tell me that.
Mark
