Bed mounting Bolts
Old Nov 25, 2010 | 03:24 AM
ChaseTruck754's Avatar
ChaseTruck754
Working on my own stuff in my "spare" time all the time means I am in the shop by myself 99.9% of the time. Getting used to this has led me to some "interesting" ways to do certain tasks. It can get a little scary at times but it keeps me alert and strong so I'm ok with it!
Old Nov 25, 2010 | 05:50 AM
Fordby4's Avatar
Fordby4
I have a carrage bolt that is loose, but can't tighten it or loosen it, any thoughts, I might consider weld/tack the bolt just so I can tighten it up
Old Nov 25, 2010 | 07:02 AM
Diesel_Brad's Avatar
Diesel_Brad
Weld a nut on the top of it so you can get it out , then replace it w a regular bolt
Old Nov 25, 2010 | 10:12 AM
Fordby4's Avatar
Fordby4
Good idea, thanks
Old Nov 27, 2010 | 04:41 PM
caspermj's Avatar
caspermj
So what size/length bolt is needed? I just got a steel box to replace the wood flat bed that's on my truck and am not sure the proper size??? Thanks.
Old Nov 27, 2010 | 10:19 PM
Drac's Avatar
Drac
Save the old ones
As Mike pointed out the original bolts are more than your run of the mill carriage bolts. The square is both longer and larger than the ole hardware store carriage bolts. However, they will work.
As for using hex headed bolts, they work too. Just don't unload that dirt with a flat shovel or your nutz might get a poke from the handle when it catches a bolt head.
Old Nov 28, 2010 | 07:59 AM
caspermj's Avatar
caspermj
I guess what I was looking for is 1/2" x 3", or 7/16" x 5", etc... I have no idea what the original bolt size was since I never had the original box on my truck, just the wooden flat bed. I'm sure I could figure out something that would work, just thought it would be easier to hear from someone who has already replaced theirs with standard bolts (instead of the stock carriage bolts). Anyone?
Old Nov 28, 2010 | 11:27 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The originals were 1/2"-13 on the size, can't help on the length right now. I won't be home for another 3 1/2 weeks so I can't measure the ones I have but I believe they are around 3" long.
Old Nov 28, 2010 | 12:09 PM
nothercrash's Avatar
nothercrash
There ar several different lengths. Some of the bed crossbeams are about an inch deeper than others, and so some of the bolts are about an inch longer. I think it's 4 and 4, but I'll check.
Old Nov 28, 2010 | 04:02 PM
4x4 Bart's Avatar
4x4 Bart
I don't think it's a good idea to use standard carriage bolts instead of the original bed bolts. The original bolts are much tougher. I think they are grade 5, plus the head and square shank is much larger adding to its strength. Hardware store carriage bolts would be grade 2.
In a accident the bed could pop off the carriage bolt heads or pull the head through the large square holes in the sheet metal..
Grade 5 hex heads with a washer would solve the safety problem but set up a little high for sliding cargo in without snagging.
When I'm in the wrecking yard looking for parts I carry a 3/4" socket just in case I run across some good bed bolts. Most are rusty.
Old Nov 28, 2010 | 04:14 PM
mikeo0o0o0's Avatar
mikeo0o0o0
According to the Ford parts catalog:
Bolt, step 1/2"-13 X 3 3/4"
Fits:
73-up F100/350 reg cab
P/N 384865-S40
Old Nov 28, 2010 | 04:50 PM
caspermj's Avatar
caspermj
Perfect! Thanks very much
brown78
Aug 24, 2016 12:20 PM
TucsonF100
Mar 30, 2016 08:16 PM
matt2491
Dec 24, 2015 09:53 PM
Ziob
Dec 3, 2015 06:51 AM
ctann
Sep 16, 2012 05:10 PM
