Bed Mounts and Transfer Case Mounts for 1960 F100 4x4
I am getting close to re-installing the bed on my 1960 F100 4x4. The wood blocks were degraded and impossible to model to re-create. Any ideas where to source these? I can't seem to find transfer case mounts either, LMC just has later model mounts. Haven't checked cab mounts yet and may have a similar issue there too!? Thank you!! Don
Here is a thread that shows the dimensions of the bed blocks!https://www.ford-trucks.com/forums/1...ng-blocks.html
And here is the transfer case mounts I used they are not rubber like original but polyurethane. Much stiffer and the case does not flex as much under torque.1968-1979 Ford F Series Truck Transfer Case Mounts, Black-Broncograveyard.com
Good luck in your quest!
PS I made my bed blocks from Maple but Im sure any hardwood will work fine.
fatdaddy
07-02-2002 10:54 AM
