Iam helping a friend diagnosis a no start problem on his e99 250. Truck cranks but wont fire up. All stock except for a TS chip. Here are the codes they got .
po460-fuel level sender A
po220-throttle/pedal position sensor cucuit B
po231-fuel pump secondary circuit low
p1464-A/C on during koer cct test
p1536-park brake applied failure
p0380-glow plug/heater cucuit A
p1396-glow plug monitor fault bank No.2
p1395-glow plug monitor falt bank No.1
A few months ago I help them when they was stuck on the road . I was able to get it started when I stuck my hand down behind the fuel bowl and while I was wiggling the wires it started . Could it be the fuel bowl heater ? or IPR ? .Those were the wires that I wiggled around . It lasted about 3months now its doing it again. I didnt have time to look at it this time so they had someone pull codes .
Out of all the codes which ones would cause a no start issue ?
Okay guys come on and jump on in . I need your help here . Any more advise ? What other things should I be looking at ? Would the ICP and IPR throw a code if there is a problem ? I heard it wouldn't .
