Sponsored by: Auxito
headliner problems
Old Nov 22, 2010 | 06:56 PM
jrod117's Avatar
jrod117
headliner problems
Hi my names Jarod I just bought a 1998 f150 extended cab 4.6l v8 with 180,000 miles for 2900$. I thought it was a pretty good deal. The only problem I found was when I was driving it home about 10 minutes ago, and it was when I folded down the sun blocker/mirror thing, and about 3 inches of headliner came down with it. It's just along the front and it's all the way along from driver to passenger side. If any of you have had this problem and know how to fix or have any advise at all please share it. I'm not to worried about but I would love to get it fixed.
Old Nov 23, 2010 | 01:00 PM
tomascamblor's Avatar
tomascamblor
I just had to remove mine to fix a leak in the rear window seal and I think, can't look at it right now, but I'm pretty sure the sun visors are mounted thru the head liner. Now if it is the actual hard part that is comming down it may 1) be broken from someone trying to yanking on it rather than removing it properly Or 2) they just reinstalled it wrong. If I remember right there is some kind of spacer or washer that is under the mounts for the visors. Are those loose? Now if it's just the fabric then you just need some adhesive, but make sure its for headliners or it might discolor the fabric. Hope this helps.
davewave649
18
Apr 8, 2021 11:33 PM
changoo
1997 - 2003 F150
Dec 2, 2010 05:48 AM
phubble
17
Mar 13, 2010 08:05 PM
18fan
May 19, 2004 11:32 AM
sethro
Dec 2, 2003 08:46 AM
