Sponsored by: Real Truck
2010 F350 code p1335
Old Nov 22, 2010 | 02:27 PM
r0guenj's Avatar
r0guenj
out of a random act today I checked for some codes and see p1335 on my banks iQ.
P1335: EGR position sensor minimum/maximum stop performance - This code means that the EGR valve position voltage is greater than the allowable limit when closed and is not being commanded by the PCM. I have two different specifications for this: 1.3V>2.5 seconds and 1.5V>2.5 seconds but the indication is still the same. The possibilities include a stuck EGR valve, debris preventing the valve from fully closing, wiring concerns affecting the signal voltage or control circuits and the PCM.
-19000 miles and it was just in for service last week (oil change, fuel filters, tire rotation)
-no CEL or any indication that there was any problem other than a couple of extra regens over the last week.
-truck has the six gun tuner, iQ, Ram Air intake, and Monster Exhaust.installed.
-dieselkleen cetane boost is added usually every other tank
what does it mean and should i bother taking it in again with no other symptoms?
I occasionally (once in a blue moon) get p2002 because of the intake, but I have never seen any other codes on this truck until today.
should I clear the code and wait for a re-occurence? or is it serious enough that it cant wait and let the dealer see the code first?
Old Nov 22, 2010 | 02:44 PM
senix's Avatar
senix
Personally I'd check the wiring where it connects to the EGR valve. Ensure you have good contacts and just watch it.
i eat hybrids
May 20, 2017 10:15 PM
4Snow
6.4L Power Stroke Diesel
Jan 13, 2017 09:26 AM
anotherhappycamper
1978 - 1996 Big Bronco
Jun 6, 2013 08:17 AM
Racin07jason
May 8, 2012 06:26 AM
