Sponsored by: Innova
need some advice
Old Nov 21, 2010 | 08:40 PM
havns3's Avatar
havns3
need some advice
KENWOOD KFC-C6893PS 6x8" / 5x7" 3-WAY SPKRS
looking at this speakers to put in my super cab f-250
two in front doors two in back. most all reviews seem to be good. going to hook it up to my factory head unit for now. would i need to amp these is up a little or will the headunit provide enough to make them sound better then the stock ones.
Old Nov 21, 2010 | 09:14 PM
bgalaxy67's Avatar
bgalaxy67
You won't need an amp at all with them. They will sound great without one.
Old Nov 21, 2010 | 09:29 PM
havns3's Avatar
havns3
thanks i figured they would but just wanted someone to back me up on it as it has been a long time since actually bought aftermarket audio. next i am trying to talk wife into a kenwood dnx 7160 headunit but this is going to be a tough nut to crack on that one.
Old Nov 21, 2010 | 09:39 PM
havns3's Avatar
havns3
any idea where i can get the adapters to go from the kenwoods to the factory wiring?
Old Dec 2, 2010 | 07:27 PM
havns3's Avatar
havns3
ok i got the speakers and the adapter wires more when i get a chance to get them
Old Dec 2, 2010 | 08:42 PM
Scootimus's Avatar
Scootimus
Where did you find the adapter wires?
Old Dec 2, 2010 | 10:06 PM
havns3's Avatar
havns3
2 Pairs Metra 72-5600 Ford Speaker Adapter New - eBay (item 280528607935 end time Dec-28-10 06:31:28 PST)
make sure to google for your year truck there are different apaters for different years
Old Dec 2, 2010 | 11:37 PM
fz1dave's Avatar
fz1dave
Super Duty
$21?
Be a lot cheaper to just snip the factory clip off and use new connectors.
Old Dec 3, 2010 | 05:34 AM
havns3's Avatar
havns3
Originally Posted by fz1dave
$21?
yes but then if i wanted to return it back to stock i would have to rework the plug plus this way i do not have to worry about a crimped connector coming loose.
Old Dec 3, 2010 | 09:07 AM
MPTonyT's Avatar
MPTonyT
I left my connectors on and just spliced into the wire and soldered on the ends that came with my Alpines. that way if i want to return to stock i can very easily and it didn't cost me anything.
Old Dec 3, 2010 | 11:02 AM
fz1dave's Avatar
fz1dave
Super Duty
So cut the wire back a couple inches from the stock connector and save that piece in case you went back to stock. Then just splice it back. And always solder your connections. That way you won't have to worry about anything coming loose.
What MPTonyT said would work too.
Just seems like a waste of $21 for a simple fix that's all.
Old Dec 3, 2010 | 11:17 AM
MPTonyT's Avatar
MPTonyT
I suggest soldering the wire directly to the speaker. That way if you ever have to troubleshoot you have piece of mind that that is not the issue.
Old Dec 3, 2010 | 09:18 PM
havns3's Avatar
havns3
thanks for the input guys but i already have the adapters. its just easier for me this way. hope to have them installed tomorrow. now i have to search on how to get the door panels off
Old Dec 4, 2010 | 03:35 PM
havns3's Avatar
havns3
Got the speakers in they are a lot better then the stock ones for sure. might need to amp them though. adapters for the wires worked great had the speakers installed in 35 minutes easy. are the adapters worth it for some probably not, were they worth it to me absolutely.
Old Dec 5, 2010 | 09:24 AM
havns3's Avatar
havns3
So now that i got my speakers installed i have another question. will this amp work with those speakers?
Kenwood KAC-6404 Car Amplifier
Detailed item info
Product Identifiers
Brand Kenwood
Model KAC-6404
MPN KAC-6404
UPC 19048176110
Key Features
Amplifier Type Multi Channels
Channels 4-Channel
Bridgeable Bridgable
RMS Power at 2 Ohms 60 W x 4
RMS Power at 4 Ohms 40 W x 4
Performance
Frequency Response 50 Hz - 0.2 Hz
Signal to Noise Ratio 94 dB
THD at Rated RMS Power 0.8 %
Crossover / Equalizer
Bass Boost With Bass Boost
High - Pass Frequency 80 Hz - 80 Hz
Low - Pass Frequency 50 Hz - 200 Hz
Technical Features
MOSFET Circuitry Yes
3 Way Ready Yes
Dimensions
Width 13.75 in.
Depth 9.13 in.
Height 2.38 in.
here is the speaker info:
240 watts peak power
2-80 watts RMS power
# Diamond Array Pattern polypropylene woofer
Rubber Surround
Image enhancer IV technology
1-3/16" PEI balanced dome tweeter
3/8" Ceramic flat tweeter
# 4-ohm impedance
# frequency response: 80-22000 Hz
# sensitivity: 87 dB
digruk
Modular V8 (4.6L, 5.4L)
Feb 26, 2015 08:20 PM
Grinder Man
Oct 10, 2014 09:35 AM
rloomis482
Feb 13, 2013 05:43 PM
ten.mile
Dec 11, 2012 05:56 PM
dreuter
13
Apr 24, 2010 06:31 PM
