carb choice
Old Dec 18, 2009 | 04:54 PM
dreuter's Avatar
dreuter
carb choice
New to the site I'll make this my intoduction thread here too I guess. Lurker for a few weeks to get gen. info I needed for the truck. It had not been driven in 5 years hadn't left the turkey farm in 10.
Back to the question at hand.
Ive got it narrowed down a Autolite 4100 (1.12)
"Spreadbore" or an Autolite 4100 (1.12) no "Spreadbore" or not labled that way.
a 1985 f150 4x4 lariat w/HD sus*****on up front not sure how to tell in back
efi exhaust manifold
clifford intake manifold
Maybe a walker y (unless I get a better idea Hint Hint)
maybe a cat
some type of turbo exhaust muffler or a 1 in 2 out flowmaster 40
What would be the benifits of the spreadbore over the "regular" 4100 be? or vice versa?
Thanks
Dan
Old Dec 18, 2009 | 10:14 PM
Harte3's Avatar
Harte3
Ford Truck Enthusiasts Forums - Search Results
Try there...easily found by entering "spreadbore" or "spread bore" as a term in the Search function box.
Old Dec 19, 2009 | 06:35 AM
chrlsful's Avatar
chrlsful
maybe a cat
Thanks
Dan
HiYa & Welcome (too)!
What motor, what use (I guess the 300)? This is an already assembled vehicle?
(En)Join da fun!
Old Dec 19, 2009 | 07:49 AM
chrlsful's Avatar
chrlsful
It took me here: (ford-trucks.com/forums/search.php?searchid=1470412). Where do I enter my question? Way up top? Jeesh, screen looks complicated 2 me.
TIA,
cf
(look out 4 the 18" fallin!)
Old Dec 19, 2009 | 01:56 PM
F-250 restorer's Avatar
F-250 restorer
maybe a cat
Thanks
Dan
Hey there. I have quite a bit of experiance with the 4100. First of all, Autolite never made a spread bore. All 4100's are square bores. Pony Carburetors makes an 'internal' spread bore by taking a 1.12 verturi (600 cfm) carb and installing a shim, so to speak, over the venturi, reducing the diameter to 1.00". Having different jet sizes in primary and secondaries does not make it a spread bore.
It is a great carb, and easy to work on. The rebuild kits are cheap, about $20 at Napa, but because so many collectors want them for original restorations for Mustangs and 60's era cars, they have become expensive. Unless you get lucky, even a core at the swap meet will cost you $100 at the swap meet. If you want it rebuilt by Pony Carbs, and they are the only ones who make the 'spreadbore', it will cost an additional $500. I have done it.
The idea behind the spread bore is to do your daily driving on the small venturi side, and then have the larger boosters when you need the neck-snap accelleration.
Having said that, I will say that I had a 1.08 (480 cfm) on my hp 300, with ported head and over-size valves. It was plenty for that engine. If your engine is not modified, then a 600 cfm, or 1.12 4100 may be too big for it. If you can turn the carb over and can see that the primary venturi are physically smaller than the secondaries, then Pony Carbs has worked on it. Ford put that carb on 390's and 427's!
If you keep it, then you will need the 1/8" plate that Pony sells to sit between the carb and manifold to prevent vacuum leaks. For $20 it is well worth it.
I would add: That carb was last made in 1968! It is at least 41 years old. Surfaces warp, tiny passages get clogged or distorted and leak. You might make it work really well on a 300 by experimenting with different Holley jets, maybe not. If you found a cheap one, I'd say give it a whirl. If you are going to pay top dollar with Pony, I'd say the money is much better speant on an Edelbrock 500 for $300, completely new, or even rebuild a Holley that is not quite so old.
Good luck.
<a href="http://s659.photobucket.com/albums/uu316/bobbyrogue/?action=view&current=P1010153.jpg" target="_blank"><img src="http://i659.photobucket.com/albums/uu316/bobbyrogue/P1010153.jpg" border="0" alt="autolite 4100"></a>
Below is a shot of the 4100 on the new engine. This is before the carb was sent to Pony.
<a href="http://s659.photobucket.com/albums/uu316/bobbyrogue/?action=view&current=P1010174.jpg" target="_blank"><img src="http://i659.photobucket.com/albums/uu316/bobbyrogue/P1010174.jpg" border="0" alt="last details getting sorted out"></a>
Old Dec 19, 2009 | 08:01 PM
chrlsful's Avatar
chrlsful
Looks like U built your self a heck of a motor! Thanks for the shots, esp of the R side of that carb.
Now lets C if it helps him.
Old Dec 19, 2009 | 09:54 PM
F-250 restorer
Hey, Chad, or whatever your name is, I didn't write that for you, nor post the photos for you. It was to help the guy who started the thread. If you have something to say to me, im me, or better yet, just butt out. I don't like you, and don't want anything to do with you. I've made that clear. Now stay out of my posts. This forum is to share helpful info, so zip it.
Old Dec 20, 2009 | 05:55 PM
dreuter's Avatar
dreuter
Restorer
Thanks, useally not on this end of the new guy " hazing" / let get my post count up side of a forum. Been a member of some Bmw and M3 forums for a 6 or 7 years you always have guys who bring nothing to a thread or the op's question. Wreched on my weekend track rat for afew years now and learned alot. A bmw inline 6 is very different from a ford 6. I useally just skim past the nonsense to the info that helps me with my question and/or problem. Again thanks for you help your post are some of the first I noticed on the forum Along with Harte3 and sorry about not useing the search not sure where my head was at. Thanks for your guys insite and knowledge.
dreuter
Old Dec 20, 2009 | 10:29 PM
Harte3's Avatar
Harte3
The search is not the easiest feature to obtain the results one wants but can work with a little work. Not a situation unique to this Forum but happens on others too like FSP and Speed Talk.
Old Dec 21, 2009 | 05:54 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
There is no hazing ...enjoy FTE and keep posting...a ton of help here from the guys.
Restorer
Thanks, usually not on this end of the new guy " hazing" / let get my post count up side of a forum. Been a member of some BMW and M3 forums for a 6 or 7 years you always have guys who bring nothing to a thread or the op's question. Wrenched on my weekend track rat for a few years now and learned a lot. A BMW inline 6 is very different from a ford 6. I usually just skim past the nonsense to the info that helps me with my question and/or problem. Again thanks for you help your post are some of the first I noticed on the forum Along with Harte3 and sorry about not using the search not sure where my head was at. Thanks for your guys incite and knowledge.
dreuter
Old Jan 14, 2010 | 10:17 PM
dreuter's Avatar
dreuter
F-250 restorer what lokar bracket did you use?
Lokar SRK-4000 - Lokar Throttle Cable Brackets - Overview - SummitRacing.com
Lokar SRK-4001 - Lokar Throttle Cable Brackets - Overview - SummitRacing.com
I went with the autolite 4100. Hope to get this in the truck soon. A few parts need blasted and powder coated but hope fully soon.
Thanks again
Dan
Old Jan 15, 2010 | 12:26 AM
F-250 restorer
[quote=dreuter;8369971]F-250 restorer what lokar bracket did you use?
Hey guy--
Yeah, those are the brackets I used. They work really well. The only tip I would give you is this: Use the Clifford or Offy C intake. With the 4100 on a DP intake, you have to mount it 90 degrees to the engine. That means the mixture screws are ... nearly impossible to get at. I am not exagerating! I tried to make a tool, cut off screwdrivers, and got multiple burns laying across the engine trying to tune it, or just to turn down the idle. You don't have that problem with the Clifford or Offy C.
I would say that the 4100 is a great carb. I hope you went with the 1.08 venturi, which is 480 cfm. When the secondaries open it's a kick in the butt! Also, because the base of the 4100 is so narrow, it is difficult to get a seal. Pony Carburetors sells a 1/8" plate which mirrors a base gasket, and it solves the problem.
Good luck.
**I also want to say that for a while after the installation, be checking inside the venturi for about a week to make sure nothing is leaking. And smell your dip stick periodically to make sure it doesn't smell like gas. That's always a good idea with a rebuilt carb. It's a lot earsier and cheaper to repair a carb than bearings!
Old Apr 24, 2010 | 04:16 PM
dreuter's Avatar
dreuter
little update after afew weeks of sitting the truck started up today.
had alittle problem
https://www.ford-trucks.com/forums/9...from-carb.html
I have a few questions / concerns
it seems to be pretty loud in the engine bay is this normal with a clifford and efi manifolds?
Alittle smokey after it heats up. I tried to clean up the block when everything was appart
Im hopeing its just left over cleaner or oil. Any other guesses?
I have some tinkering left to do I may make a video of it and see if you guys can find anything i cant think of.
thanks
Dan
Old Apr 24, 2010 | 06:31 PM
F-250 restorer
had alittle problem
thanks
Dan
Dan: You don't say which size 4100 you went with. Just in front of the throttle, on the float housing, you'll see a clock face. Inside that it will either say 1.08, or 1.12. Which one do you have?
The noise may be from aftermarket air cleaner...the carb drawing?
Also, did you use the plate from Pony Carbs like I mentioned? If not, while running, spray a little starting fluid around the base of the carb and see is the idle goes up. If you, you have a vacuum leak.
What rpm are you idling at? You should be able to turn that idle screw down until the engine stalls.
If you don't answer these questions, then we can't help you because we don't know what you have or what it is doing.
Big-Sarge
6.7L Power Stroke Diesel
47
Jan 17, 2024 10:32 PM
vortec 1
Nov 28, 2018 10:44 AM
kindorotten
Ford Truck Parts for Sale
Jul 23, 2016 10:13 AM
rloomis482
Feb 13, 2013 05:43 PM
Kirbys73F100
Jul 16, 2010 09:25 AM
