hello guys i was told to post my question here so here goes. just bought 1990 f350 7.3 with e4od transmission. had shifting problem first, replaced tps and adjusted with volt meter. help a little not much, it wants to stack 3rd and 4th together. also was changing fuel fiter today, noticed a wire harness lays across left fender well with 5 or 6 wires pluged together was melted, anybody tell me what they are or should i be having some trouble out of this? thanks in advance,and i,m new to site so bare with me till i figer out where i,m supposed to be. thanks
the block is your engine harness. the 2 wires melted go to your glow plug controller. if it fires your alright. if not, you can clip the wires on each end of the plug and put a heavy gauge butt connector. OR you can run a single heavier gauge wire to the controller
One problems guys, this is on the right fender, he said he found the messed-up plug on the left fender... Lotsa connectors there, especially with the E4OD - what color and shape is the damaged connector, and where exactly on the fender is it located?
thanks guys, that is the right plug i,m talking about. its on the left fender facing motor. everythings working on the truck except shifting 3rd to 4th really quick, but i can live with that. thanks for the photo of what i was talking about, i,m really a computer idiot lol.
Understand your cautious approach. I read between the lines and figured he didn't know his difference between hs right and left.
FYI: If your working on a vehicle, location is based on if your sittingin the driver's seat. In America passenger side is RIGHT, driver side is LEFT.
