pats key can't program
Old Nov 24, 2010 | 03:49 PM
No-Tyme's Avatar
No-Tyme
Originally Posted by 70f100longbed
the program additional keys setting is turned off in the PATS module which will require a IDS scan tool to change.
The problem is that the 2 Ford dealers that I have been to, or that I go to (third one screwed me over) won't tell me straight up what the cost will be... It's like if they get me in the door they rake me over the hot coals.
You may be able to answer my next question: If I go to the dealer and ask them to re-set my ECM and the 2 keys that I have, will that wipe out any other keys that have been previously programed? I don't like the idea of having keys floating around for my truck.
Old Nov 24, 2010 | 09:32 PM
cb_13's Avatar
cb_13
They can do an ignition key code erase and it will take two keys to start the truck and they will be the only functioning keys then.
Old Nov 25, 2010 | 09:22 AM
No-Tyme's Avatar
No-Tyme
Wonderful: Thank you for that information...
Old Dec 5, 2010 | 10:08 AM
No-Tyme's Avatar
No-Tyme
**Update**
I wanted to post this update as I have solved my problem with the programming issue... it seems the first key I purchased on eBay was defective. I purchased a second key (from a different seller) and took the key to have it cut at the local hardware store, and it programed without a hitch.
If you are interested in the sellers of either the good or the bad key you can look up my feedback on eBay by searching for "Ida-Boy" and finding the sellers.
Thanks to all for you reply's...
Old Dec 5, 2010 | 11:51 AM
n5926g's Avatar
n5926g
Excellent....Ebay is good in most instances,but not all.Glad it worked out for you.
Old Dec 5, 2010 | 08:27 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Exclamation
got some wrong info in this thread.
go here for a full review of how the PATS system works and how to program it.
https://www.ford-trucks.com/forums/9...pats-info.html - if all else fails, the Owners Manual says it pretty clearly IMO
as for the PCM being "full"...no. It will hold 8 keys maximum as Shorebird said. however, when you enter the programming mode, all keys get deleted from the system except the 2 used to enter the programming mode. The PATS module then has 6 additional slots that can be utilized. This happens every time you enter the programming mode. So be sure to have all keys at that time or you'll have keys that won't work until they get re-programmed to the truck
Sorry you ended up with a defective key. But luckily it was a relatively simple fix. I've been buying those eBay PATS keys for years without any issues. I'd make the original seller refund/replace the bad key. especially as you've proved it was his product that was faulty.
Old Dec 6, 2010 | 04:12 PM
No-Tyme's Avatar
No-Tyme
This is a question that I asked but didn't get a compete answer till you explained it...
Thank you!!!
Tylus
2004 - 2008 F150
74
Oct 25, 2019 02:18 AM
dchamberlain
1997 - 2003 F150
50
Apr 27, 2019 10:59 AM
RV Tow'n Truck
Oct 28, 2016 08:08 PM
73fan
Feb 24, 2016 06:41 PM
jas88
1997 - 2003 F150
24
Jun 22, 2009 03:01 PM
