Well thanks for all the feed back guys. I moved my alignment to Monday and Wednesday i'll install the new front shocks and stabilizer. Next question...I'll probably get new rims and tires in May. Do I need another alignment? I'm thinking no, but some people have told me anytime you get new tires you need one.
If this info has not been followed or close to it you maybe in for some deep pocket shock.. Plus also replacing the inner axles seals as well.
This lubes the upper king pin bearings and the axle u-joints as well. This is for the standard closed knuckle end tubes. When buying new wheels you better check first the back spacing for tie rod end clearance issues. .my 2cents
orich
