Elec fuel pump
Old Nov 19, 2010 | 04:11 PM
ro.walker's Avatar
ro.walker
Elec fuel pump
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtvisited="1"><!-- / icon and title --><!-- message -->
I have an 89 F-150 4X4, with a 5.0. I have a problem with the fuel pump continuing to run after the key is turned off. It does this occassionaly but not all the time. There are no leaks in the fuel system. Is there a switch that tells the fuel pump to run or is this some type of failure in the pump. The only way to stop it from running is to disconnect the battery, Would it be acceptable to install a toggle switch to use to cut the power to the pump.
Thanks
Old Nov 19, 2010 | 04:20 PM
rla2005's Avatar
rla2005
I would suspect your Fuel Pump Relay is sticking closed.
Electric Diagram from Ford Fuel Injection:
Physical location courtesy of Subford:
oleman's Avatar
oleman
The fuel pump is driven by a relay. It probably has sticking contacts.
Replace it and see if it helps.
Old Nov 19, 2010 | 04:29 PM
ro.walker's Avatar
ro.walker
Thanks, I expect you guys are exactly right. will get me a new one and try it.
Old Nov 19, 2010 | 06:15 PM
ro.walker's Avatar
ro.walker
Just bought one and put it on, I have my fingers crossed , everything is OK right this minute. The picture is not the same as my truck but it put me on the right track, I did find it. Thanks a lot.
Micbruff
23
Nov 5, 2014 08:17 PM
wagonerkl
22
Dec 5, 2013 08:15 PM
Jnas860
Jul 30, 2013 02:54 PM
5Rangers
Jul 25, 2011 09:42 PM
rexpendergraft
15
Oct 20, 2010 06:36 PM
