Where would i look to see what size bulbs all of the outside lights are as well as the inside mqp lights or w/e their called are? Its a 95 supercab f150. And the light inside is just the one middle light and the two map lights on each side. I dnt have any kind of overhead console or anything.
If you've got the owners manual they will be listed in there. If you don't have it, pull what you need and take it to the store, that will be the best way to get what you need.
or you can always try one of those machines at walmart they always have set up... has been pretty accurate for me.. or just call your local parts store and they can tell you which ones your truck takes
High & low beam headlamp
9007
9007SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9007ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9007XV XtraVision Halogen - The Brighter Light
9007CB Cool Blue Halogen - The Whiter Light
Parking light
916
Front turn signal
3157
3157LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
3157
Tail light
3157
Stop light
3157
High mount stop light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
922
922LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
H3
H3ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
97
Back up light
3156
3156LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
Rear sidemarker
194NA
194NALL Long Life Upgrade: Up to twice the life of the standard lamp
Ash tray
161
161LL Long Life Upgrade: Up to twice the life of the standard lamp
Glove box
161
Map light
105
Step/Courtesy light
561
89
912
912LL Long Life Upgrade: Up to twice the life of the standard lamp
Trunk/Cargo area
906
906LL Long Life Upgrade: Up to twice the life of the standard lamp
922
Under hood light
912
Instrument-general
161
194
8605
Check engine indicator
194
Hi-beam indicator
194
Seat belt indicator
194
Brake warning
194
Automatic transmission indicator
194
Directional signal indicator
194
Uhm just for the map and dome lights, glovebox, ashtray, and license plate lights. Im leaving the outside ones alone for now and im not pulling out my dash to change the bulbs lol
Nothing to pulling the dash apart. Search on here. There is a big thread on LED dash lights.
Which dome light do you have? The newer style or older? If older go ahead and do the "taurus dome swap" then convert to LEDs. The newer style dome lights are 100x better.
Im not sure which done light i have. My friends in auo tech at the career center we go to and he said its a b$&@! To take out the dash but ill look it up.
I like the ash try looks. Thats what im going for on the inside, different colors.
So is replacing the bulb all i need for those lights i listed tbat i want to change?
Ill do a search on the taurus dome swap as well as the dash lights. But not sure about my dome light. Its a 95?
I also have a rollpan but i have the regular plate lights on it. I just wanna replace those with some leds and im going to get one of those bars of fire or wgatever their called for my tailgate
I was going to give you more rep points 86, but it won't let me. Anyway, good post with the bulb specs.
I also did the dome light swap. I got one out of a Super Duty, but its the same idea. Its 10 times better than the old chrome one with the yellow lense.
