Light bulbs
Old Nov 23, 2010 | 04:13 PM
86F150302's Avatar
86F150302
Originally Posted by xc4jokestomper
Oh wow that does seem easy now that ive seen the write up.
How do i get the headlight switch in and out? And how do i get to the bolts for the ac?
Just unplug the headlight switch from the back.
I have pics of the AC in that write up also. Shows all the screws you have to take out.
Originally Posted by TexasGuy001
I was going to give you more rep points 86, but it won't let me. Anyway, good post with the bulb specs.
I also did the dome light swap. I got one out of a Super Duty, but its the same idea. Its 10 times better than the old chrome one with the yellow lense.
Np bud Thank you anyways
Yes I love the newer dome light. So much better. When I had the stocker I pulled the plastic cover off just so I could see better.
Old Nov 23, 2010 | 04:49 PM
xc4jokestomper's Avatar
xc4jokestomper
Do i not have to remove the **** before i pull the bolts?
Old Nov 23, 2010 | 06:56 PM
86F150302's Avatar
86F150302
For the AC no.
Old Nov 23, 2010 | 07:04 PM
xc4jokestomper
No i mean the headlight **** do i have to remove it before i pull the bezel? And if so how?
Old Nov 23, 2010 | 09:47 PM
86F150302's Avatar
86F150302
Yes you have to remove it.
Here ya go. 1st time taking it off is hard but after that its a piece of cake.
Thanks for the rep points everyone. Make a post on here and ill get ya back
Old Nov 26, 2010 | 04:16 PM
truckrider814's Avatar
truckrider814
has anyone tried the weld x6 one's ?
Old Nov 26, 2010 | 04:34 PM
86F150302's Avatar
86F150302
For the dash lights? Really have to have a 360* bulb for the dash lights.
Old Nov 30, 2010 | 09:22 PM
truckrider814
now for a toughie that i can't find what's the light number for the od light on a 91?
Old Nov 30, 2010 | 09:50 PM
86F150302's Avatar
86F150302
Guessing the OD light is the same as my 94.. I just pulled it apart tonight to see. Not sure if ill be able to put a different LED in it..
Ill post pics.. Gotta figure this new camera out.
Its all soldered. Also doesn't look like it comes apart anymore than what you see.
Old Nov 30, 2010 | 10:05 PM
truckrider814
I got leds for the gauge and the a/c turns and the headlights and wiper but the only one left is the od light. when i opened it its just a bulb with two wire leads wrapped around the holder so i might try going to radio shack and get one like that. also does anyone know where the speedometer cable come through the firewall cause i for the life of me can't find it and apparently i gotta take a clip off there to make slack in the cable so i can finally get my cluster out.
Old Dec 1, 2010 | 12:36 AM
86F150302's Avatar
86F150302
Yes radio shack sells individual little LEDs.
Old Dec 1, 2010 | 05:33 PM
truckrider814
ok so the ones from radio shack suck, 3.66 later. but i found some on super bright leds. btw the od light on mine is the style thats on the dash board, i just have to measure the size an try it out kinda stupid to pay 1.27 something then 5 bucks for shipping but what can ya do. im still trying to find where the speedo cable goes through the firewall.
Old May 1, 2011 | 07:19 PM
  #28
xc4jokestomper
alright im looking on super bright leds.com and im having trouble. i dont wanna order the wrong ones so which ones do i need? anyone have a link or part number? i ordered some a while back but i ordered the wrong ones. i got ones with a single led in it before i knew that i needed a 360' type. so i used those in my license plate light and tonight i just switched out my a/c controls. alot easier than i thought but im going to have to see how bright they are. im going to go ahead and switch those over as well.
anyone have a link to the kind i need for the cluster and A/C?
Old May 1, 2011 | 08:01 PM
  #29
86F150302's Avatar
86F150302
I have the part number on my nloc write up. I would get it but im on my phone and barely have service. I posted he link earlier in this thread.
Old May 1, 2011 | 08:12 PM
  #30
xc4jokestomper
Thanks man i found them. Would you recommend the super bright leds or the ebay ones? It looks like your came out fine?
