Overdrive buton not working
Old Nov 19, 2010 | 07:57 AM
bcg's Avatar
bcg
My OD button on the shifter has stopped working and I don't even know where to begin on troubleshooting that. Any help you guys can offer, I'd really appreciate. Thanks!
Old Nov 19, 2010 | 08:05 AM
ford390gashog's Avatar
ford390gashog
Very common issue try search for "broken shifter wires" "OD button not working" its an easy fix the wires in the column rub and break.
Old Nov 19, 2010 | 09:51 AM
Supercab's Avatar
Supercab
What causes the wires inside the column to rub and break? just using the truck-driving it-moving the tilt-wheel-moving the shifter????
Old Nov 19, 2010 | 10:03 AM
woodnthings's Avatar
woodnthings
I put together a little article to help show the problems with the wire getting chafed. Usually it will blow a fuse and cause loss of the dash and throttle pedal.
Here it is Transmission Shifter Wire Repair
Hope it helps. You may also find that the button has gone haywire and needs replaced, but the wires getting damaged is usually the case.
wrd0225
Sep 30, 2014 10:53 PM
jeffgies
Testing.....
Jul 26, 2011 07:49 PM
stevcher
2004 - 2008 F150
Feb 7, 2010 03:14 PM
Pablo-UA
Aerostar
17
Oct 20, 2007 02:35 AM
preppypyro
British Columbia
84
Aug 17, 2007 11:40 AM
