Aerostar Ford Aerostar
Blower wont working.
Old Oct 15, 2007 | 12:18 AM
Pablo-UA's Avatar
Pablo-UA
Sometemes it works, when I drive faster 45 mph it start working. How to disassembly blower motor to fix it?
Old Oct 15, 2007 | 07:30 AM
krankshaft's Avatar
krankshaft
Did you check the blower motor resistor. Remove it to make sure that the resistive wire coils are intact.
Maybe at higher speeds the vibrations are causing it to make contact?
Old Oct 15, 2007 | 07:35 AM
Pablo-UA's Avatar
Pablo-UA
It seems to me motor is not OK.... Voltage on motor is 11.2 V, but no draw.
Old Oct 15, 2007 | 08:41 AM
krankshaft's Avatar
krankshaft
Did you try connecting the blower directly to the battery? If so and the motor still doesn't turn read on.
I have opened DC and AC motors before so here are some basic things to check.
Spin the shaft and feel if its binding. If it is lubricate it and test if its not.
Check to see if the brushes are worn. If the motor has alot of miles on it thats a possibility. The motor would then be making intermittant contact.
The brushes are at the back of the motor in little holders pushed by springs against the rear of the rotor shaft.
Also check for a burnt commutator (the thing that the brushes make contact with on the rotor) if its burnt the motor is shot. The commutator switches the polarity so that the rotor shaft is constantly opposing or "chasing" the opposite magnetic field.
Some DC motors are brushless but since I have never opened an Aero blower I can't say which type the Aero has. If the motor is brushless there is not much you can do for it. Other than lube the shaft if its binding.
Old Oct 15, 2007 | 12:28 PM
96_4wdr's Avatar
96_4wdr
piece of debris caught and binding between fan motor housing and fan blade?
Old Oct 15, 2007 | 08:22 PM
Aeroman59's Avatar
Aeroman59
Sounds like you have a motor windings fault. Try the brushes if it has them. Make sure all connections are good.
Aeroman
Old Oct 15, 2007 | 10:11 PM
krankshaft's Avatar
krankshaft
If it is the winding there is either an open from a broken piece of enameled wire or the insulation of an enameled wire failed causing a short. In either case a new blower is in order.
Old Oct 16, 2007 | 12:10 AM
Pablo-UA's Avatar
Pablo-UA
Blower has just been rebuilt. Brushes were replaced with ones from Volvo Truck alternator. Hope will work for many years.
Old Oct 16, 2007 | 04:56 AM
96_4wdr's Avatar
96_4wdr
another great DIYer repair by pablo-ua
Old Oct 16, 2007 | 09:29 AM
krankshaft's Avatar
krankshaft
Using brushes out of an alternator I never thought of that.
Good job .
Old Oct 16, 2007 | 10:54 AM
96_4wdr's Avatar
96_4wdr
yeh, pablo just took the alternator brushes and made them run reverse rotation and turned it into an electric motor
Old Oct 16, 2007 | 01:59 PM
Pablo-UA's Avatar
Pablo-UA
No!!!!! direction is correct! :-))
Old Oct 17, 2007 | 02:46 PM
pinceau's Avatar
pinceau
I have the same problem, two years ago i changed the brushes (don't laugh, I have cut in two parts a brush from a Peugeot diesel starter with two copper lines, and put it to the correct size with a file); since last summer the blower is erratic, sometime it run, sometime not, i have to move the climate fonction handle side to side before it start ( mine is 1989, with the old dashboard), sometime it start alone when the van jerk on a bump, sometime i have to stop, open the hood, and shake the motor connector, really irritating......
Pablo, the motor is easy to open with a little chisel: the brush plate is crimped on the motor, you juste have to insert paper clips to hold the brushes open when reassembling; the bad new is that I think crimping can't be done too much time.
Old Oct 18, 2007 | 01:00 AM
Pablo-UA's Avatar
Pablo-UA
I did my blower for less then one hour. It worked for 17 years before w/o any problem.
BTW. There are parts in Aero made in france. Tailgate lock and wiper motor.
Old Oct 18, 2007 | 01:02 AM
Pablo-UA's Avatar
Pablo-UA
Pinceau! How correctly to say your name? (I was in France twice (draw to Spaine throught Cote'd'Azur), but I can not understand any france word!)
