Sponsored by: Auxito
Tire size help
Old Nov 19, 2010 | 12:28 AM
Vaccuum's Avatar
Vaccuum
Tire size help
I have a 2002 F150 5.4.
I bought it from my work bud.
He put these awful 20" super wide, low profile rims/tires on it.
A guy is offering me a set of 30x10.5xR15 with 90% new condition tires for $300. All-terrain. A little more tread than I was after.
I really am looking for a stock set, but the price might be right.
Not too sure what the numbers mean in relation to the truck.
The wheels on now rub on a sharp turn and the tire drag kills the MPG real bad.
Is this tire an appropriate size for the truck?
Thank for the help.
Mike Perez
Old Nov 19, 2010 | 04:54 AM
Mawk's Avatar
Mawk
No it won't work. You need at least 16" rims to clear you calipers so just with the info provided I can already tell you it won't work. Those 15" rims will contact the caliper.
Whatever you get will also have to be in a 5x135 lug nut pattern. There were a few different tire size options for the 97-04H F150's, so easiest way to find what came stock is to check sticker on the door jamb.
Old Nov 19, 2010 | 07:46 PM
Fox Fader's Avatar
Fox Fader
What would be the proper offset for 16x9 wheels?
Some pics would be nice.
Old Nov 19, 2010 | 11:40 PM
Hybris's Avatar
Hybris
Thank for the help.
Mike Perez
Buy the tires and turn right around and sell them for a good bit more. Just my opinion.
For the size I can say that anything less than a 30 inch diameter tire will fit a dead stock truck in tire sizes that comes to (I'm getting these numbers from the Miata Tire size calculator based on what you said.)
Original factory tire size 235/70R16
235/55R20
245/55R20
255/50R20
265/50R20
I can't say for sure if anything wider than 265 will fit from what I have heard 285 is widest you can run without rubbing with stock suspension but I have not been able to confirm that.
I hope this helps I also offer this as a good source to figure out all the tricky details of modern tire tech.
Tire Tech at Tire Rack
Old Nov 20, 2010 | 06:46 PM
Fox Fader's Avatar
Fox Fader
I'm running 285/75/16 on mine with no rubbing issues at all.
Old Nov 21, 2010 | 09:02 AM
galaxie641's Avatar
galaxie641
285's on a 4wd-- 265's on a 2wd.
Stock size was probably 265/70/17 unless it is a 2wd.
Old Nov 21, 2010 | 09:17 PM
Vaccuum's Avatar
Vaccuum
Yup, it's 2 wheel drive.
Ford_Six
General Automotive Discussion
23
Mar 13, 2012 02:22 PM
Mike-11
Dec 29, 2010 02:30 AM
Ford_Six
May 23, 2010 07:41 AM
joshua_perez1980
New Mexico Chapter
Feb 17, 2009 08:08 AM
fordguywa
Computer Chips & Tuners
Mar 16, 2002 01:23 PM
