brake light problems
Old Nov 17, 2010 | 07:16 PM
customcab66's Avatar
customcab66
hey got a question to pose any of you with the old slick fords have problems with the conections at the brake switch getting covered in crud so they dont work i did not have this problem until i let the truck sit in portland for two months now i cant keep them from messing up any ideas on what i can to to stop this problem thanks
Old Nov 17, 2010 | 08:03 PM
Customcab's Avatar
Customcab
I never had that type of problem; I have had grounds fail to make good contact, I also recommend cleaning all your connections and then use electrical grease to help seal them. Also check the contacts of the fuse at the fuse panel. They attend to get loose over time as well. Do your blinkers (Turn signals) still work?
If so then its not a fuse issue!
galaxie521
Bronco II
May 3, 2013 11:58 PM
DPASCUZZI
Large Truck
Oct 25, 2012 09:51 AM
whiteyteryx
Aug 10, 2011 02:06 PM
gazbiz
Dec 14, 2007 10:37 AM
rocky39742
20
Sep 11, 2007 05:03 PM
