Need a little help...
Old Nov 17, 2010 | 01:52 PM
NightNDayProjects's Avatar
NightNDayProjects
I bought this new project and it has zero identification. That I can find at least... Thought if I threw some pictures to the experts here, you might be able to help out. I'm pretty sure that it is a 51. Any help would be greatly appreciated!
Old Nov 17, 2010 | 02:51 PM
51PanelMan's Avatar
51PanelMan
Looks to be a 52. It does have the front hood trim from a 51. Hood can be from a 51 with 52 side trim added on. Can you post larger pictures?
Look for a VIN tag inside the glove box. The VIN should also be stamped on the right side frame rail around the front axle area. You'll likely need to wire brush that area to find it. If it is a 51, which is doubtful, look for another VIN tag to be affixed in the upper right corner of the firewall. If it's missing, then look for four holes. If it's a 52, this tag will be missing and you'll only see the depressions of the hole, but not punched all the way through.
Here's the difference between 51 and 52 shown in pictures.
1951 hood side trim
1952 hood side trim
1951 front view (note 3 openings in front of hood and trim; also note the location of V8 emblem).
1952 front view (note only 2 opening in front of hood and different trim; also note F-O-R-D letters in place where V8 trim went on 51).
Old Nov 17, 2010 | 03:43 PM
larryb346's Avatar
larryb346
cool looking project.
I would suggest you not spend a dime on your new project until you get the vin number and title fixed. Some on here can tell you after they spent a ton of money on their projects they had great issues getting a title if they even could get one.
I would want the title in my hand before I sent another dime on it.
Just my opinion.
Larry
Old Nov 17, 2010 | 03:50 PM
thndrroad70's Avatar
thndrroad70
Cant answere your question but sure like the cool vintage Chopped project!!! 48-52 somewhere between there anyway..... if there arent no Id on the truck anywhere it shouldnt be hard to find a "Donor" door somewhere to make it into something .... correct me if I am wrong but I assume thats where they secured the tag on that era Ford trucks also??
Old Nov 17, 2010 | 07:16 PM
NightNDayProjects
Thaks guys! I appreciate the info. There will be a donor truck underneath it. All my reg will be put under the vin of the frame and running gear. Most likely will be a '05/'06 Ford F150 4x4. It will take a little doing but it'll be worth it! I'll see if I can post some larger pics.
Thanks
Old Nov 17, 2010 | 07:22 PM
NightNDayProjects
These should be larger pics
Old Nov 17, 2010 | 09:50 PM
husker's Avatar
husker
Did you get a title with the truck?
In Kansas, I think you can get a title on a 50 year old vehicle if you have a bill of sale. They check that it isn't reported stolen and then issue the title. At least that was the policy a few years ago.
It was done I think to help people title and save old vehicles that had be sitting in a shed or where the original owners were long gone with no way to go back to get a title. Now, I haven't tried this for a few years, so the law may have changed.
The down side is you have to have liability insurance and the vehicle inspected to get the title.
All states are a little different on how they handle this.
The 48 F5 in my signiture was titled with only a bill of sale, but it wasn't and isn't running and I didn't want to purchase insurance for a future project, so I just applied for a off road title. If I get it road worthy, I'll have to take for inspection and apply for an on road title.
Old Nov 18, 2010 | 12:17 AM
NightNDayProjects
Thanks Husker, title and reg shouldn't be a problem. I'm in canada and the truck is in the states. Since I'm not going to be using the original frame and motor, just the body of the vehicle. It will be classified as parts entering Canada and when I go to insure and register upon completion, the truck will be registered as the main portion of the vehicle. The newer F150 truck hiding underneath the F100.
Old Nov 18, 2010 | 12:22 AM
Julies Cool F1's Avatar
Julies Cool F1
I think you got your answer (look at the front right top frame rail by the shock mount for the serial number)
But I wanted to say Welcome to FTE
If you find that number, post it and we can tell you what it was built as/with.
Old Nov 18, 2010 | 02:47 AM
iwanaflattie's Avatar
iwanaflattie
welcome is the top chopped on it
Old Nov 18, 2010 | 08:31 AM
56panelford's Avatar
56panelford
Top kind of looks chopped to me too. Nice looking project
Old Nov 18, 2010 | 09:53 AM
51PanelMan's Avatar
51PanelMan
Also has F2-F6 front fenders. It's a toss up as to what year it is without knowing the VIN. Could be a 51 with a 52 F2-F6 frong clip and hood side molding, or a 52 with 52 F2-F6 front clip and a 51 hood with 52 hood side moldings.
Good luck on the frame swap. It won't be easy.
Old Nov 18, 2010 | 06:16 PM
NightNDayProjects
Wow! Thanks everyone. I will post the vin as soon as I have it. Going to go and pick it up on sat morning! The top is chopped by the way.
Old Nov 19, 2010 | 12:03 AM
Julies Cool F1
Originally Posted by 51PanelMan
Also has F2-F6 front fenders. .
Hmmmm are you sure? It's a little hard to see in the photo, but the fender seam almost looks level with the wheel well opening. Hard to tell!
But definately some mixing going on there!
Old Nov 20, 2010 | 11:59 AM
epp's Avatar
epp
love chopped tops i will taking 3" outta mine when i get around to paint and body work.
Welcome to the forum. Theres lots of great folks here to help you with any questions you may have as your project progress's
