E4OD Bang Shifting
Old Nov 17, 2010 | 10:10 AM
bluesmanmike5's Avatar
bluesmanmike5
E4OD Bang Shifting
We have a 93 Lightning with the e4od tranny. My boss blew the gears out of it, so we replaced the stock ring & pinion with a set from Summit Racing. We got rid of the 4:11s and replaced the with 4:56s. It shifted fine while we were breaking in the new set of gears. then one day it just started shifting really hard. Went to a tranny shop and the pulled the codes. Said the VSS was bad. Replaced that, same thing. So I did some research on here and replaced the MLPS, and it has been replaced before, had the new wire connections already installed. It still slams into gear really hard, all gear shifts. It wants to about break your neck. I see some post about line pressure increasing to prevent clutch slippage. What would cause this to do that, any ideas?
Old Nov 17, 2010 | 10:51 AM
Lazy K's Avatar
Lazy K
Not an expert but I would check that the tone ring in the diff was still good.
Ceaumar
Mar 8, 2019 09:37 PM
Animus
Apr 29, 2017 05:25 PM
VanMam
Feb 23, 2017 09:03 PM
grumpyinme.
Nov 8, 2016 07:46 AM
fordtrck302
Apr 5, 2008 05:52 PM
