Mounting Stereo Components
Old Nov 17, 2010 | 10:05 AM
02xxx's Avatar
02xxx
I have searched but did not find any good posts. I am trying to install two amps and a box for a 12inch sub does anyone have a good write up on installing components under the middle row seats?? For the sub I am thinking of making it a quick disco just in case I need the room. Thanks
Old Nov 17, 2010 | 06:36 PM
tdappleman's Avatar
tdappleman
I have the second row captain's chairs but had no problems mounting my sub amp under the right side. The door sills pop off easily to help route the wires under the carpet and to the amp location. The biggest thing I found was to make sure the amp gets good ventilation - mine has less than an inch from the bottom of the seat but the amp stays relatively cool to the touch. Recommendation would be to run signal/speaker wires down one side of the truck and power down the other to help reduce or eliminate feedback. The sub box is easy enough if you are just going to make it a quick disconnect. I mounted my subs in the rear doors as I didn't want to lose any room or have to move a box around.
BrassMonkey
1997 - 2003 F150
19
Apr 16, 2011 04:04 PM
nosfrog
2004 - 2008 F150
Apr 8, 2005 07:34 PM
dynocompe
2004 - 2008 F150
Sep 18, 2004 05:52 PM
Veeha
Jul 9, 2004 07:42 PM
dking69
Jan 10, 2002 08:15 AM
