72 F 250 acceleration
I recently rebuilt carb, new timing set, fuel pump, cap and rotor, plugs, water pump and alternator on my newly purchased 72' F 250 w/360. I am unfamiliar with truck but no stranger to old cars and I am still trying to get choke set correctly, so that may be part of this question. When I am on highway and push on gas I hear and feel it really pick up for a second or two then drops off, it will still accelerate but not the fast pick up that it should.. any thoughts?
Sorry for late reply and there are no stupid questions. Yes timing marks were lined up when installed, I did a dry float level check have not done it since carb has been installed. Mixture is good, pressure is good and I am 99% sure butterfly opens all the way I will check float and butterfly tomorrow. Thank you
When you rebuilt the carb which power valve did you put in it? It's rating should be approx. 1/2 of the engine's vacuum signal at idle. I.E. if your engine has 14" of vacuum at idle the power valve should be a "6.5".
Or, the tranny isn't shifting back out of Passing Gear prematurely is it?
Fixnstuff
52
05-06-2021 08:12 AM
86ford302help
72
01-29-2013 09:23 PM
rdweathers
16
04-11-2011 07:12 PM
adamsre
02-24-2005 05:09 AM
