Winter Oil
Old Nov 16, 2010 | 04:06 PM
martin123456789's Avatar
martin123456789
Winter Oil
Hi,
I did a oil change a week ago with 15w40 and I forgot about changing to a winter oil..
And the cold weather is just sweeping in.. it's just a matter of days before I see 15F temperatures.
Can I just blend half my 15w40 oil already in my truck with say arctic oil? Or should I do a complete oil change? Go synthetic?
I have a fumoto valve.
Any thoughts? Thanks
Old Nov 16, 2010 | 04:21 PM
Krump's brother's Avatar
Krump's brother
I'm no expert on engines, nor on oil. Disclaimer over.
If you still have the bottles, switch it out with some 5W 40 and use the old oil in all of your other stuff that takes oil-snowblowers, tractors, etc. If you haven't put many miles on it, put it back in this spring.
Old Nov 16, 2010 | 04:24 PM
npccpartsman's Avatar
npccpartsman
Excellent advice. Not like you "hurt" the oil in a week.
Old Nov 16, 2010 | 04:37 PM
Jigger2020's Avatar
Jigger2020
did you use "winter oil" last year?
Old Nov 16, 2010 | 04:49 PM
martin123456789
It'll be my first winter with a diesel truck... so far, dumping the oil out to be reused might be the best solution.. :S
Old Nov 16, 2010 | 04:52 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Depends on how cold it gets..... if it doesn't get below freezing (wherever you are), I wouldn't worry about it. If it's only 15*F, I wouldn't worry too much. Got a place to plug it in?
Old Nov 16, 2010 | 05:25 PM
martin123456789
More than likely, this truck will see -40F... I'm in Canada
Old Nov 16, 2010 | 05:35 PM
SFC-REMF's Avatar
SFC-REMF
You might want to switch to a 0w if it gets that cold. I am in AK and running T6 rotella 5w but I'm in anchorage so our coldest temps are around -10. That being said it is starting to get col here as well, I can defiantly tell the difference in the 5w as apposed to the 15w.
Old Nov 16, 2010 | 05:37 PM
Nitrous's Avatar
Nitrous
If you will be seeing 40 below, I think it would be a good idea to go down to Canadian Tire and get some 0w-40. It will idle very rough for a while on 15w 40 at that temperature.
Old Nov 16, 2010 | 06:29 PM
dakotajeep's Avatar
dakotajeep
Dude
You most definately need to use a different weight oil. Reguardless of what you do with the old oil at this point.
That is coming from a guy that understands those bitter cold days.....
Thad
Old Nov 16, 2010 | 07:05 PM
sarnott140's Avatar
sarnott140
I too live in Canada, switching from 15w40 to 0w40 syn in the winter is the best thing i ever did, WAAAY smoother startup
Old Nov 16, 2010 | 07:46 PM
sandmanf250's Avatar
sandmanf250
winter oil
shell rotella year round .if your in -20 below or more ,plug it in for at least 2 hours.that's a 6.0 ,if it's a 7.3 ,same oil but leave it pluged in overnight
Old Nov 16, 2010 | 09:35 PM
caere's Avatar
caere
I run the Motorcraft 10W-30 year round with no issues, as the ford dealer recommends. I always plug it in though. It makes for smoother starts and I assume it's easier on the motor. I was wondering about using synthetic but I usually do my oil changes around 5, 000KM (3,000 miles). Perhaps a bit short of oil changes, but I have always believed that oil is the life blood of an engine. And since I don't use synthetic I do them closer together than recommended. The dealership says to do oil changes every 8,000 km (5,000 miles)
I just put in some REVX and it definitely made a difference. The truck runs a bit quieter on start-up. Less ticking.
From Winnipeg Manitoba, Canada. We often have a few weeks of -20ºF if not more with windchill. Brrrrrrr!
Old Nov 17, 2010 | 07:47 AM
origcharger's Avatar
origcharger
If you only drain out 1/2 or 7 quarts of your 15W-40, you will still have 7 plus the 4 that never drain out for nearly 3 gallons of 15W-40 to go with about 2 gallons of whatever you put in.
Mr James
Nov 17, 2013 05:35 PM
MUJA1001
Apr 18, 2011 02:45 PM
Moto52
Nov 19, 2010 12:28 PM
nico963
Jan 5, 2010 01:34 AM
f350peter
Nov 8, 2007 04:39 AM
