6.0 stalling issue hhhhelp
Old Nov 5, 2010 | 06:43 AM
Rambo76's Avatar
Rambo76
My 2004 F350 with a 6.0 PSD will stall sometimes. Every so often when I start the truck the front left headlight will be dim. When this happens and I use the wipers, headlights, and heat basicly use accessories the wipers will move slowly and the truck will stall when you pull on the highbeams.
I know when the truck does this because when I turn on the headlights the left turn signal arrow on the dash appears to be partially lit up.
I have replaced both batterys and was thinking alternator but this problem isn't always there only every so often. I have no Idea any help would be greatly appreciated.
Old Nov 5, 2010 | 06:26 PM
Rambo76's Avatar
Rambo76
anyone???????????????
Old Nov 5, 2010 | 06:31 PM
Maxium4x4's Avatar
Maxium4x4
I will have your post moved to the 6.0L Forum. Check the alternator output yet? Does the truck start after charging the batteries?
Old Nov 5, 2010 | 06:48 PM
Rambo76's Avatar
Rambo76
The shop that checked and replaced the battery's said the alternator was fine. The only reason I didn't think it was the alternator because the problem isn't always there. Truck starts great after the new batterys too.
Old Nov 5, 2010 | 09:42 PM
6litremachine's Avatar
6litremachine
have your alt load tested, have seen some wierd stuff from intermittent alternators.
Old Nov 7, 2010 | 10:42 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the 6.0L forum.
Old Nov 17, 2010 | 10:00 AM
Rambo76's Avatar
Rambo76
Well it wasn't the alternator. I am going to have to check for a bad ground or something. I have noticed today also that the windshield washer fuild sprays out when having this issue also. This is frustrating ahhhhhh.
Old Nov 17, 2010 | 10:16 AM
brickie's Avatar
brickie
Ground is on the bottom of the block passengers side.
