cruise control does not work
Old Nov 22, 2010 | 08:24 PM
ronjon95's Avatar
ronjon95
Ok guys got it fixed it was the switch. The springs where broke down just like the one shown above. I also found that the plastic retainer ring was about to fall off from wear. So I went to the Stealership and got another one and replaced it was $7.00 and some change. Thanks again another repair from FTE!!!!
Old Dec 17, 2010 | 07:48 AM
robs01f250's Avatar
robs01f250
can this switch be changed without taking off the rod that connects to the master cylinder?
Old Dec 17, 2010 | 07:12 PM
F350-6's Avatar
F350-6
Yes. There's a U shaped plastic clip that hold it onto the rod. The clip runs the full length of the switch so it's almost like you're pulling the switch in half. When you get the new one out of the box and play with it, you'll see how it comes apart, then you can remove the bad one.
Old Dec 19, 2010 | 10:17 PM
kelwar's Avatar
kelwar
My truck the springs broke in the clutch position sensor also so I just replaced the springs and it has been good ever scince
kelwar's Avatar
kelwar
My truck the springs broke in the clutch position sensor also so I just replaced the springs and it has been good ever since
Old Dec 19, 2010 | 10:39 PM
robs01f250's Avatar
robs01f250
Where did you find the springs at?
Old Dec 19, 2010 | 11:08 PM
kelwar's Avatar
kelwar
I bought the springs at princess auto (in canada not sure where you can get them in the US) I got a bag of like 100 with all different sizes for like $4 for it was worth the 4 springs I used to fix the switch (was not any long enough so I stacked a couple) .... oh and sorry about the double post above
http://www.princessauto.com/surplus/...-pc-spring-kit
Old Aug 17, 2011 | 06:16 PM
herzonh's Avatar
herzonh
can someone help me my speed control does not work what could be the issue i already change several part and no luck. i drive a 2002 f350 7.3L
Old Aug 17, 2011 | 06:27 PM
ronjon95's Avatar
ronjon95
What exactly have you changed out??
Old Jul 3, 2014 | 10:49 PM
dave r d's Avatar
dave r d
My light is on at the dash replaced pressure switch on master cyl and it still will not work V-10 with auto 1999 f350 dually Thanks Dave
Old Jul 4, 2014 | 08:37 AM
Tugly's Avatar
Tugly
The pressure switch didn't give me a light on the dash - just no cruise control. What light is on? The ABS light?
mah77
Apr 14, 2018 12:52 PM
DDT11
Aug 31, 2017 07:15 PM
notacharger
Nov 8, 2016 05:26 PM
FordTruckfan89
May 11, 2016 09:46 PM
Chalkie
6.4L Power Stroke Diesel
18
Sep 11, 2014 10:21 PM
