'03 Expy AC not blowing cold???
Old Nov 13, 2010 | 09:42 PM
Big AC's Avatar
Big AC
Does anyone know how to recharge the cooling system or where to find pictures of a diagram so I can do it myself? Not sure if this is what's needed, but I'm looking for the cheapest possibilities first.
AC blows and the air is just not getting cold.
Old Nov 22, 2010 | 01:30 PM
david888's Avatar
david888
It is probably your blend door . It is probably broken. heatertreater.net can fix this issue. I did one on my nav and it was easy.
Or you can test the A/C first. Find the low side valve. Its eather up near the drier(canister) on the firewall or at the compressor itself. Simply put the gauge to it and read it. If its under or around 30 PSI then you need some freon.
Otherwise if your A/C is on and all that is coming out is heat then your blend door is broken which is a commen problem. The website I gave hear will save you about $1000 at the shop. You can do it with ease and save bucks. they have videos and a full writeup for the shadetree mechanic on there page.
Old Nov 22, 2010 | 05:08 PM
projectSHO89's Avatar
projectSHO89
Go to the HVAC forum and see the FAQs.
Old Nov 23, 2010 | 07:50 AM
broncoholic's Avatar
broncoholic
Do you have rear air also? Does it blow cold or same temp as front? The front and rear use the same a/c system, so if one blows a noticeably different temp, then you definitely have a blend door issue. If they both blow about the same temp, then you can try a recharge. The location is near the battery. There are two lines (high pressure, low pressure) and the recharge cans you get from the auto parts store will only fit onto the correct line, kinda fool proof. I did a little recharge on my 03 with front/rear a/c and found that the system pressure reads higher than the recommended range provided with the recharge can. After reading around on the internet, I came up with the dual system needing a higher pressure, I believe 60-70 psi, but don't quote me on it. Good luck
CLE-PRE
Jan 9, 2017 09:41 PM
Molonlabe1776
Jun 3, 2016 12:14 AM
eddieniner
May 14, 2016 11:00 AM
5504x4drwcrew
Oct 16, 2011 09:42 PM
Ricky Mayo
Sep 28, 2010 09:05 PM
