2003 Ford Explorer leaking something?
Old Nov 13, 2010 | 11:07 AM
Fordrider22's Avatar
Fordrider22
Post 2003 Ford Explorer leaking something?
I just noticed my Ford Explorer is leaking something from the front end. Its a very small drop. It is some type of sticky oil. Any help appreciated. Thanks
Old Nov 13, 2010 | 01:13 PM
shorod's Avatar
shorod
Seriously, you're going to need to give us more to work with than this. Where, exactly, is the leak happening - left, right, ahead of radiator, just behind radiator, near the front of the front tires, etc. What color is the fluid? Have you stuck your head underneath and looked for the source? Have you checked fluid levels to see if one is low? Did you just have the oil and filter changed?
-Rod
Old Nov 13, 2010 | 05:58 PM
Fordrider22
I will check the fluids tomorrow. I had a oil change done 2 weeks ago. I just had my bearing replaced in my front left wheel.
Ford Explorer Man
New Member Introductions
Jun 25, 2014 10:12 AM
turk1124
Feb 8, 2008 07:59 AM
cjohummer
Oct 7, 2001 10:18 PM
Don
1978 - 1996 Big Bronco
Mar 1, 2000 12:36 PM
