gas leak
Old Oct 6, 2001 | 12:49 AM
cjohummer's Avatar
cjohummer
gas leak
Old Oct 6, 2001 | 07:01 PM
slothshady's Avatar
slothshady
gas leak
ive got a pretty bad leak coming from my tank. its got a steady drip. i was wondering how hard/expensive would it be to fix?
Old Oct 6, 2001 | 10:04 PM
Franklin2's Avatar
Franklin2
gas leak
Look here. It's $88.00.
http://www.raybuck.com/Page_34.html
Old Oct 6, 2001 | 10:26 PM
stryder's Avatar
stryder
gas leak
I can tell you one thing. NONE of the different puttys/sealers work. I've tried them all and still had a leak. They might last a few days, maybe even a few weeks, but the leak will come back. I just decided to save up for a new tank.
Stryder
I'd rather be walking through a hot desert carrying a Ford hubcap than driving a POS Chevy
Old Oct 7, 2001 | 07:10 PM
79fordslug's Avatar
79fordslug
gas leak
My tank wore through at the steel straps. It was my only driver so I had to act quickly. I went to NAPA where it just so happened they had a tank for my truck. It was $114 out the door. The toughest part is the bolts for the straps. If they are rusty, you might just break them off and get new ones. It is not a difficult job. Use a floor jack under the tank to support it. You can lower it a couple of inches to unplug the sensor wires and fill/vapor tubes. Do it right and get new hoses. I did not replace my sending unit, as long as it is working, save your money. Make sure you use some gasket seal at the top of the new tank where the sending unit fits, the gasket is not a perfect seal. Good luck!
Old Oct 7, 2001 | 10:18 PM
Franklin2's Avatar
Franklin2
gas leak
The place I mentioned above http://www.raybuck.com/Page_34.html
also has new straps, locking rings and seals. And oh, by the way, I did mention the tank is only $88.00.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
