detroit locker help?
Old Nov 12, 2010 | 10:55 PM
ford2000ex's Avatar
ford2000ex
i have a 2000 Ford excursion 2wd, Limited with a v10. my axle number is 31. 3.73 non limited slip gear ratio> what detroit locker will fit my x?
Old Nov 13, 2010 | 02:03 AM
wallz's Avatar
wallz
Are you looking for the full locker, or the true trac(limited slip)?
You want to look for the part #'s for the sterling 10.25/10.5 axle. The gear ring is reused from your set now. If and when you go this route, you might want to have the carrier bearings replaced while in there. Being now 10 yrs old, the last thing you want is all the work done and then shortly after needing to get back in there to replace bearings. Also a good time to look at getting the alum finned diff cover, or other. The cover has to come off, and you replace the fluid any ways. I have heard from previous posts, and lucked out when I had mine put in, that the true trac works best with the amsoil brand.
Old Nov 13, 2010 | 06:40 PM
CrzHelm's Avatar
CrzHelm
I would not put a locker in vehicle thats driven on the hwy. any bends in the road make for a very stressfull drive especially on congested roads. your vehicle just want to go straight and you have to fight to stay in lane. if your on and off the gas it does all kinds of under and over steer.
Old Nov 13, 2010 | 08:27 PM
ford2000ex's Avatar
ford2000ex
so i am better off getting the trutac limited slip?
Old Nov 13, 2010 | 08:35 PM
Stewart_H's Avatar
Stewart_H
Unless you do a lot of drag racing at the local track, a limited slip diff is almost always your best bet.
I used to do a lot of drag racing in my Lightning and I still went with a Truetrac, and not a full locker.
Stewart
Old Nov 13, 2010 | 08:38 PM
ford2000ex's Avatar
ford2000ex
Okay.. sounds good. to me. ill be ordering this badboy up... after i get it, ill post some pictures... to show my progress.. n kool stuff.. yeah my diff cover is Completely rusted i am pretty sure i can pick my way through the rusted metal
Old Nov 13, 2010 | 09:03 PM
ford2000ex's Avatar
ford2000ex
Detroit Locker 915A550 Detroit Truetrac Differentials
that one should fit no problem correct?
V10E350
Mar 12, 2015 06:22 PM
purplewg
27
Feb 18, 2015 12:25 PM
61steven
31
Feb 3, 2014 02:01 PM
wvabeer
Dec 17, 2004 07:38 PM
doop
Dec 9, 1999 07:42 PM
