Changing the trany fluid
Old Nov 11, 2010 | 09:42 PM
Dutter's Avatar
Dutter
i got a 94 ranger with a 4.0 and a auto trany, how many courts do i need and dos it have a filter
Old Nov 11, 2010 | 10:18 PM
g_k50's Avatar
g_k50
Yes, check the owner's manual, if you do the whole drain and refill, you'll need 14-15 quarts, if you just drain the pan and cooler you'll need 4-5.
Old Nov 11, 2010 | 11:06 PM
KhanTyranitar's Avatar
KhanTyranitar
Make sure you replace the filter when you change the fluid. Refill with MerconV fluid.
Old Nov 12, 2010 | 12:08 AM
Dutter's Avatar
Dutter
Yeah i dont have the manual so that why i was hopen you guys would know, and should i do a hole drain with filter or just a flush with the pan and a filter, because right now its shifting a little ruff
Old Nov 12, 2010 | 08:02 AM
pawpaw's Avatar
pawpaw
Is your Ranger a 4X4, or 4X2????
The 4X4 has a slightly deeper tranny pan & a filter with a longer neck, so it'll stay immersed when off roading at steep angles. SO, make sure you get the right filter, pan gasket & fluid.
Capacity is 10-10.3 qts, depending on if it's a 4X2, or 4X4 & if it has an aux tranny cooler, so get a 12 qt case of multi-vehicle, Motorcraft Mercon-V licensed fluid.
I agree that with the tanny shifting acting out, that a pan drop, filter change, then continuing on with a full tranny fluid pumpout would be best, as the pan drop will allow you clean it & the magnet & to get a better idea of whats going on in there in the way of deposits & the full fluid pumpout will get most all of the old fluid out of the valve body, torque converter, cooler & lines.
Here is how I do it on my 99 4X2.
https://www.ford-trucks.com/forums/6...-pump-out.html
Let us know how it goes.
Old Nov 12, 2010 | 11:22 AM
Dutter's Avatar
Dutter
alright, and yes its 4x4, But how do i pump out the old oil, and how much money am i looking at for a full flush on the trany, or could i get away with a semi flush with the pan and filter.
Old Nov 12, 2010 | 02:07 PM
pawpaw's Avatar
pawpaw
Read through the link I posted.
Old Nov 12, 2010 | 02:12 PM
Lazy K's Avatar
Lazy K
Click on the link given by pawpaw and follow his directions. You will not need to do anything else.
Old Nov 12, 2010 | 02:46 PM
Dutter's Avatar
Dutter
oow alright i didnt see that ill check it out thanks
