back space
Old Oct 24, 2000 | 05:36 PM
bigbo's Avatar
bigbo
back space
I have a 2000, xlt expedition, I want to replace the factory wheels, does any body know the correct back spacing and bolt pattern to order?
thanks a ton!
Old Oct 29, 2000 | 01:47 PM
thermo's Avatar
thermo
Veteran: Navy
back space
The Expedition uses a 5-135 bolt pattern with a +20 mm offset as I recall. Most tire/wheel places can verify what offset there is. I found the offset at my local tire shop by looking through one of their manuals as I was waiting for a tire to get mounted. I wouldn't worry too much about the offset unless you are going to a really wide tire (ie, 295 or wider-aka 11" or wider). I ran for awhile a set of 315/75r16's which worked fine for on the street(other than having to trim the front valance a little bit), but offroading the tires would have rubbed some. So, that should help you out.
Chris "Thermo" Coleman
Old Oct 29, 2000 | 09:12 PM
FTE Ken's Avatar
FTE Ken
back space
fljab
Florida Chapter
Nov 24, 2016 08:01 AM
BrittsNFords
Feb 6, 2016 03:22 PM
lm987
Mar 11, 2014 01:44 PM
jonnykford
1978 - 1996 Big Bronco
May 7, 2011 03:35 AM
TD
May 18, 2000 02:22 PM
