Lift blocks in the front, and No track bar? Bad mojo...
It's going to ride extremely bad with those TTB springs in there, do yourself and get yourself a set of F350 front springs(spring rate is MUCH lower) and if you want to stay that high, a shackle reversal kit with a stock or not much more than stock spring will work nicely, ride better than oem, and not require a track bar.
thats just a temp for at the moment for a mock up, the blocks are goin by by for springs, and i havent got the track bar mocked up yet. the axle isnt even bolted in yet, just hanging from the come a longs. im priceing out springs right now, im haveing a hard time finding them.
i went back there and checked. eye to eye 54" on the 99-04 super duty f250-f350 and the 97-97 are 52" so your front shackle will be pushed 100% forward when you install.
i would. unless you want to "re arch" the psd springs. you'll get 2" out of it and they can shrink it up that 2" eye to eye. thats more $ then its worth imo. id go add a leaf.
lol, ya school books cost a ton. add a leaf on ebay is cheap enough. i bought 2 sets, cant use em though. if i had known you wanted some i could have delivered a set or two to you when i was out there.
