Short distance driving
Old Nov 10, 2010 | 10:20 PM
bmiller131's Avatar
bmiller131
I've got an '11 f250 CC, SB, FX4 and I love it. Its my first diesel so I'm still adapting/learning. A question about driving habits: I drive a very short distance to work (less than 2 miles). Most days I drop my kids off in the morning, making it more like 6 miles. On days that I don't, I have been taking the long way to work to allow things to warm up a bit. Is this necessary or am I reading old wives tales? Should I be concerned about long term issues with driving this short distance? I do get out once a week or so for a 10+ mile run on the highway. Appreciate the feedback!
Old Nov 11, 2010 | 03:56 AM
ruschejj's Avatar
ruschejj
IMO, it's not the best way to use your diesel motor but on the other hand, it should be capable of all kinds of service.
Possible Problems:
Emissions system not getting to operating temperature leading to its eventual failure.
Engine oil not getting to operating temperature, effects turbo too.
Coolant thermostats having limited cycles, prolonged periods of no movement, could stick.
EGR cooler/valve not reaching operating temperature leading to deposits and valve sticking.
The are general things that I have picked up from what other folks tend to say and I do kinda think there is reason for concern. Try to get your engine to run for an hour or so once a week, ideally with a decent load.
Old Nov 11, 2010 | 06:53 AM
bmiller131's Avatar
bmiller131
Any suggestions to minimize issues in the cold months? The summer months shouldnt be a problem b/c of the warmer weather and the fact that I'll be towing somewhat frequently.
Old Nov 11, 2010 | 08:18 AM
1994F2507.3L's Avatar
1994F2507.3L
keep it in a heated garage and plug the block heater in anyway.... unplug it back it out and let it run 15 min before leaving for work then take the long way lol
everything youve heard is pretty much true and its the same for gas or diesels if they dont reach and maintain operating temperature for some time things will start to go out. its just worse with diesels because so much relies on the engine getting to operating temp...
Old Nov 12, 2010 | 06:39 AM
fldave's Avatar
fldave
Reason to get operating temp is to evaporate any moisture in the oil and exhaust system, that's why a low mileage vehicle is not always the best.
Old Nov 12, 2010 | 06:53 AM
Marauder92V's Avatar
Marauder92V
Gotta drive them...
Absolutely agree. In small airplanes a lot of pilots have done damage to their planes by ground running them 10 to 15 minutes to get the temps "off of the pegs" in cold weather. All they have done is created moisture that eats away the internal components.
fldave is right that you need to allow the vehicle to reach operating temperatures to boil off any moisture. The big question in automobiles is how long.
Old Nov 12, 2010 | 06:56 AM
bmiller131's Avatar
bmiller131
Ok. So that's the million dollar question. How long? I am willing to leave a few minutes early and drive around. Any opinions out there? (Boy, that's a loaded question!)
Old Nov 12, 2010 | 07:06 AM
Marauder92V
It sounds like you now have an excuse to goof off and drive around a bit. Seriously, in airplanes we shoot for 30 minutes at operating temperatures (primary being oil temp). It will be hard to say how long.
In an airplane, you start, you get the temps off of the pegs during warm up, you take off at full throttle, and then set the throttle at altitude at some fixed power (sort of like setting the cruise control). Temps stabilize after you adjust the mixture for altitude, so you are basically are running at fixed power. How to translate that into automobiles with the differences in engine design and operating modes (start/stop) will be hard. But I would think, 15 to 20 minutes after reaching normal operating temps should be good.
Old Nov 12, 2010 | 08:43 AM
bmiller131's Avatar
bmiller131
Next question, what's a decent load? Does that mean hauling a trailer, or just some heavier driving (highway, etc)?
Old Nov 12, 2010 | 12:43 PM
kper05's Avatar
kper05
Whatever gets the engine hot and the best route is always a decent pull.
The most my truck has seen is 6,500.
Old Nov 12, 2010 | 01:13 PM
ruschejj's Avatar
ruschejj
My truck generally runs a lot of miles towing 6-8K worth of weight as a trailer. If you have a trailer it does not really have to be heavy. At 60mph and up we are really using most of our HP to fight aerodynamics, especially with a trailer.
Old Nov 12, 2010 | 07:26 PM
sandmanf250's Avatar
sandmanf250
short trips
use the severe service intervals listed in your manual.
Old Nov 12, 2010 | 08:15 PM
sncbluegt's Avatar
sncbluegt
Ive been told to get the turbo as hot as possible to get the moisture out of the turbo because they tend to rust and it keeps the variable vanes from opening and closing.
Wide open throttle pretty good when you do get it out.
KsHighboy
2009 - 2014 F150
15
Oct 22, 2016 09:24 PM
FlyingZebra34
Oct 17, 2014 07:57 AM
264WSM
Jun 28, 2014 10:28 AM
dispatch510
Feb 12, 2014 03:21 PM
backwoodsgoop
Apr 9, 2010 12:34 PM
