Instrument Panel Bezel Repair
Old Nov 10, 2010 | 09:26 PM
mojo79's Avatar
mojo79
The previous owner broke several attaching clips on the back side of the instrument panel. Is there a way to repair these plastic things.
Maybe some sort of hardening resin, or fiberglass body repair kit?
Anyone tried this?
Old Nov 10, 2010 | 09:38 PM
95F350XL's Avatar
95F350XL
JB Quick is very stong, and for where the 2 screws are, I just grind a washer square to fit into the hole.
Old Nov 10, 2010 | 09:52 PM
fairlane68's Avatar
fairlane68
I used epoxy on mine, and it's held up nicely. I've tried hot glue, JB Snot...whatever. The two-ton liquid epoxy worked best because it was able to envelope the fractures. It was the mounting standoffs for my rear window switch that got broken. For pickups it's the same spot as the fuel transfer switch.
Old Nov 11, 2010 | 09:08 PM
mojo79's Avatar
mojo79
So, I took the good advise from you guys and repaired my bezel this afternoon. I used plastic epoxy on three broken post and then used JB Weld on the two screw mounts for the fuel tank switch, those broke on me today... not a very sturdy piece of plastic.
I guess I'll find out tomorrow how well this works... it looked pretty good after I was done. I think it will work out Ok.
Old Nov 12, 2010 | 08:53 AM
Bunkercd's Avatar
Bunkercd
Mine was broken at the fuel switch as well. It really bugged me. So after being shocked at the prices for a new one at LMC I went to a local Pick n Pull and got a new (used) bezel for $10. Picked up an uncracked dash pad for $5! I am addicted to these places now.
Bunk
iRocco
Jun 20, 2014 08:06 PM
Guilmettedon
Electrical Systems/Wiring
Aug 7, 2003 10:02 AM
Wstrombe
Sep 21, 2002 05:52 PM
