352 Draft Tube
Old Nov 10, 2010 | 02:50 PM
65F100390's Avatar
65F100390
352 Draft Tube
I am looking at replacing the draft tube, if needed. I am told a PVC valve would be better, maybe just a breather.
What are the pros/cons of replacement of the draft tube vs just leaving it be?
Old Nov 10, 2010 | 04:23 PM
Mike G's Avatar
Mike G
Its worked for 45 years, why replace it now.... If you want to go with a breather cap, that would work too, it just vents to atmosphere. Unless of course you have some politically correct neighbors you just like to rile-up.
--Mike
Old Nov 10, 2010 | 05:20 PM
jowilker's Avatar
jowilker
No road draft FEs installed in pickups, where did this engine come from.
I say go with a pcv system.
John
Old Nov 10, 2010 | 05:44 PM
65F100390's Avatar
65F100390
I dont know. A lot of mysteries on a truck I am helping a friend with. I am thinking the tube was a add on, and will probably just go with a breather for him. But It is driving me crazy trying to figure out thats for sure. Of course on closer inspection, the fact the tube is held down by plumbers tape, should have been a clue to my pal!
Old Nov 10, 2010 | 05:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Positive Crankcase Ventilation was not a 50 state requirement until 1966 for trucks, 1971 for passenger cars.
1965/70 FE road draft tubes.
C5TZ6758A = 1965 F100/350 352.
C5AZ6758F = 1965 Passenger Car 352/390.
C6AZ6758B = 1966/68 Passenger Car 352/390/410/428.
C8OZ6758A = 1968/69 428 CJ & S/CJ, 1969/70 Galaxie 428 Police Cruisers.
Old Nov 10, 2010 | 05:47 PM
65F100390's Avatar
65F100390
PCV
Ok Joe, but do I just run a hose down the back for it? That is what I am wondering, I dont want it to splatter onto his hood or anything
Old Nov 10, 2010 | 05:56 PM
Bill W's Avatar
Bill W
most times they are run up to the air cleaner or to the intake
Old Nov 10, 2010 | 06:12 PM
65F100390's Avatar
65F100390
Yeah I see that in the books, I dont see a place on the carb or intake to hook into, any ideas?
Old Nov 10, 2010 | 06:45 PM
Boss9F100's Avatar
Boss9F100
John
The 65' 352 very well could have the road draft tube. My 65' sure does!
and its no doubt factory.
Old Nov 10, 2010 | 06:49 PM
Boss9F100's Avatar
Boss9F100
Just stick with the stock road draft tube,
as someone else said its been like that for 45+yrs why change it.
If you are really set on adding a PCV setup you could go with a different carb, or a spacer plate under the carb with attachement
Old Nov 10, 2010 | 08:42 PM
jowilker's Avatar
jowilker
Yep, Down draft tubes are well documented for pickups here on FTE.
John
montego69
Sep 26, 2016 04:27 PM
mad murdock
19
Nov 2, 2015 09:39 PM
Blitzcraig
Feb 8, 2012 11:18 PM
ibuzzard
22
Aug 13, 2010 10:39 AM
spurredon
Jul 26, 2007 10:54 AM
