Leveling kit and 35"s????
Old 11-10-2010, 09:18 AM
Bowie's Avatar
Bowie
Bowie is offline
There have been some articles on here lately about less lift more tires. I want to run 35 X 12.5 tires but I don't want a huge lift. I dont mind doing some fender trimming as long as it is just a little. Is this possible? What do some of your rigs look like?
I would like to maybe run at the leveling kit height. So 2" lift in front and no lift in the back. Thoughts??????
Old 11-10-2010, 09:21 AM
robinsonpowerstroke's Avatar
robinsonpowerstroke
robinsonpowerstroke is offline
I don't think you will get away with this without some major rubbing in the front. I have 4" and I get some very slight rub if I have the wheel turned just right and I articulate just right. It rubs on the back of the front fender.
Old 11-10-2010, 09:27 AM
Robert6401's Avatar
Robert6401
Robert6401 is offline
I also think it will rub. I am only running 285's (33's) with my leveling kit and I get rub on the leaf spring. You will have to get some wheels that have a positive offset and still probably have to do a lot of trimming. Your turning radius will most likely suffer quite a bit.
Old 11-10-2010, 09:29 AM
robinsonpowerstroke
Ya I don't get any rub on the leafs. I do not know what the offset is on my wheels but it must have more than stock.
Old 11-10-2010, 12:46 PM
Bowie's Avatar
Bowie
Bowie is offline
My current set up I don't have any wheel rub on the leafs so I have some offset. I am just wondering how low I can go and get 35" under there. Even if it takes a little trimming. Trimming just the front or front and back?
Old 11-10-2010, 01:00 PM
spunks00's Avatar
spunks00
spunks00 is offline
thats what i run, yeah it rubs a lil but all i really had to cut was the bumper. I did aftermarket springs (vs: add a leaf, front drop shackel) the only time it rubs in in turns on the inner fender now that i cut the lower corner of the bumper.
Old 11-10-2010, 04:39 PM
pbr man's Avatar
pbr man
pbr man is offline
I ran 315/75/16 on mine with just an add a leaf. I'm not sure how those compare the 12.5'' wide, but I had no issues with the tires rubbing. If I had the wheel at full lock and on rough ground it would touch the spring, but nothing serious. The add a leaf brought mine up a little less than 2'' than it was with the stock springs.
Old 11-10-2010, 04:49 PM
Bowie's Avatar
Bowie
Bowie is offline
What aftermarket springs did you go with? How did the cutting of the bumper go? What did you use? any picts you could post?
Old 11-10-2010, 06:18 PM
robs01f250's Avatar
robs01f250
robs01f250 is offline
shackle lift and you can run 35's...you will have to trim about 2.5 inches off the front bumper
Old 11-10-2010, 06:58 PM
Bowie's Avatar
Bowie
Bowie is offline
no problem with the back part of the wheel well or inner fender?
Old 11-10-2010, 07:03 PM
spinella's Avatar
spinella
spinella is offline
me too no problems really...i hve a set of bfg's 35"x12.5"x16.5 the bottom corner of my bumper is trimed my rims are 16.5x9.75 with just a superlifts leveling kit. no issues at all w/ the rear tires. i don't think it would work with oem rims. too wide of tires and the offset is'nt right. i think theres some pics in my gallery/garge.
Old 11-10-2010, 08:11 PM
bigbubba87's Avatar
bigbubba87
bigbubba87 is offline
i run 315/75/16 i dont know how close the 75 is to 12.5" wide but i have a 4" lift and my tires rub on my springs when i turn really sharp. and they also run on my mud flaps when i turn too.
Old 11-10-2010, 08:37 PM
BDalton's Avatar
BDalton
BDalton is offline
I only have a leveling kit on my truck. Here it is with 315/75R16 (35x12.50). I only rub the leafs at full wheel lock. I didn't have to trim anything and I dont rub the body anywhere, but I don't see a lot of serious offrading either.
Old 11-10-2010, 09:34 PM
rpenterics's Avatar
rpenterics
rpenterics is offline
I run 315/75R16 (were General Grabber AT2's and are now Wrangler Duratrac's) with a leveling kit (2" add a leaf) from I think it was Rough Country. I had to trim my front valance slightly and I have my the inner corners of my inner fenders pulled back (if that makes sense) I do rub from time to time when the turning with the suspension flexing. You get used to it and adjust your driving accordingly. The PO was runnin the same size tire without the leveling kit and rubbed holes through the inner fenders. I am running aftermarket wheels, not sure if that makes a difference
With PO's tires and no level
With level and AT2's
Old 11-10-2010, 11:12 PM
audioguru76's Avatar
audioguru76
audioguru76 is offline
i'd say that the backspacing could be the difference between rubbing and clearing. I'd love to have some bigger rubber under my truck (285/75/16 on stock alloys now) but I definitely don't want to do 4 inch lift to get it.
btw- rpenterics...that's one sharp truck! the 'before' pic reminds me of my truck with that rake.
Quick Reply: Leveling kit and 35"s????
