i was driving the other day lost all power on my 6.0. the gas pedal did nothing when i pushed it ruff idle when u put it in gear really bad idle. truck wont even move. i have put new fuel filters ,cam sensor,oil filter,fuel pump, cleand the egr valve still nothing . i hheld the rpm at like 3000 and it cleared up drove it for about a month and yep this week had to have it towed any thoughts
Welcome to FTE selford Give us as much information as you can, year mileage and what codes you might retrieve. Can be anything from fuel pressure to FICM. Main thing is to not throw parts at it.
young gun not sure i guess ill try to figure that out tomm. I have cleaned the egr could it still be that . im lost on this one its just odd its only showing a code for 1 3 5 7 all on one side im wondering if its the wire harnest under the valve cover
First thing that I'd be looking at is a bad copper washer under one of the injectors.
