Help with parts.
Old Nov 9, 2010 | 01:03 AM
Kustomfiend's Avatar
Kustomfiend
Help with parts.
Hi,
Not sure if I'm in the right forum...fellars get quite lumpy if one posts stuff in the wrong places. So here goes...
I'm looking for a 1967-1972 F100 part. I have been looking around on all the various truck part sites(Dennis Carpenter, LMC, Autokrafters, Blue Oval Truck Parts, Bronco graveyard) and had no luck in locating the part.
I'm looking for the coverplate that is riveted(?) to the dashboard and covers the top half of the steering column bracket, as pictured below.
I have had a go at a very reputable F100 second hand parts dealer, but after four e-mails still couldn't establish an undertstanding, whether they have the part or not.
Can anyone help? I live in New Zealand, so consider shipping, et cetera.
Thanks!
Old Nov 9, 2010 | 11:56 AM
ford4x4nut's Avatar
ford4x4nut
if you are looking for the coverplate i had the same issue and i had to find a new dash and change the odomater that was the easiest way to do it
Old Nov 9, 2010 | 01:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1967/72: There are three different types. What year, series is the truck? 2WD or 4WD? With or without P/S?
No one reproduces it, as the demand is slim and none. The only chances of finding one are either NOS or used.
Old Nov 10, 2010 | 08:54 AM
ford4x4nut's Avatar
ford4x4nut
the issue you are going to run into if you find just the coverplate is that it is riveted and numberdummy is right i have two 1970 f100's one is a part truck and is 2wd mine is 4wd and the dashes are different because mine has the oil pressure and alt gauges and and the parts truck doesnt even thought they are the same year
Old Nov 10, 2010 | 04:42 PM
Phil105's Avatar
Phil105
Originally Posted by Kustomfiend
Hi,
Thanks!
I think you might be interested in this item on Ebay. Not sure if it's what you're after or not.
1967-72 ford f100, f250, f350 ash tray & steering trim: eBay Motors (item 280584495724 end time Nov-10-10 18:03:18 PST)
Old Nov 10, 2010 | 07:29 PM
mblayton's Avatar
mblayton
I am sure he is asking about the colume cover, it is bolted not riveted and the ebay listed item is more than likely what he is after.
Old Nov 10, 2010 | 07:48 PM
crazed87bronco's Avatar
crazed87bronco
that was what i thought he was referring to. if so it's bolted from the bottom side with the bolts that hold the steering column up. what piece are you talking about NumberDummy that is pop riveted?
Old Nov 11, 2010 | 01:56 AM
NumberDummy
Open your peepers and read post #3 again. I never said word one about pop rivets!
Old Nov 11, 2010 | 02:41 AM
crazed87bronco
I was confused on what part the original poster was asking about and Ford4x4tnut's post what piece are they referring to that is pop rivited?
Old Nov 11, 2010 | 02:57 AM
NumberDummy
The part the OP is refering to is the painted cover atop the steering column that butts up against the dash.
There are three different types listed in the parts catalog.
Since the OP hasn't responded, I haven't a clue which one he needs.
They may all look the same, but looks can be deceiving.
Old Nov 11, 2010 | 03:08 AM
crazed87bronco
That's good to know I would of never thought they would have 3 types that can save me some trouble down the line any idea on why there's 3 types? And anyone have photos for comparison?
Old Nov 11, 2010 | 10:52 AM
ford4x4nut's Avatar
ford4x4nut
the cover plate for the stearing column is bolted i thought he was talking about the cover for the dash itself
Old Nov 20, 2010 | 01:59 PM
Kustomfiend
Yep, it is indeed that cover plate that goes over the top of the column.
Found the one Phil105 referred to on eBay. Thanks for the replies...
Now here's a question and it didn't occur to me at the time: What is it made out of? Aluminium or steel. I would assume it is aluminium, because of the casting burrs.
The reason I am asking is that the column is angled slightly to the left (as on American left-hand drive vehicles) and my truck is a right-hand drive vehicle, which means the column is angled to the right and I might have to do some minor modifications on the coverplate for it to work...and look right.
Um, in case "angled to the left" is confusing...inspect the coverplate of your truck and you will notice the left is shorter than the right.
Old Nov 20, 2010 | 02:05 PM
blackmajikf100's Avatar
blackmajikf100
i had an issue with finding one idk where you live but i live in hughesville pa and krahmers has like 6-8 66-72 f100s sitting around with a bunch of parts on them thats where i got mine
Old Nov 20, 2010 | 06:42 PM
seafire's Avatar
seafire
cover part
I have spare cover which came off a 70 F100 2wd automatic.
Seafire
