428 done
Old Nov 20, 2010 | 11:01 AM
73 ford guy's Avatar
73 ford guy
Comp cam techline this morning told me my cam already has a 4 degree advance in it so the stock setup should be fine on gears. As for oil additive he said one bottle is fine with use of a zinc based oil. I'm using castrol 10w/30 so he did reccomend another at least 1/2 bottle but a complete other bottle won't hurt so I'll run two.
Old Nov 22, 2010 | 05:34 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
I didnt stop to look at what cam your running in your build ? another words I didnt look it up to see what the specs are..care to shed some light on it...I'am wondering as you said , I think you running stock non adjustable rocker arms ?
Old Nov 22, 2010 | 05:55 PM
73 ford guy
<TABLE style="BORDER-COLLAPSE: collapse" border=1 cellSpacing=0 borderColor=#a6a6a6 cellPadding=2 width="100%"><TBODY><TR><TD vAlign=top align=left>High performance street, very strong mid-range with headers, 2400+ stall and lower gears.</TD><TD vAlign=top noWrap align=middle>1800
to
6000
</TD><TD bgColor=#eeeeee vAlign=top noWrap align=middle>33-248-4
</TD></TR></TBODY></TABLE>
COMP Cams 33-248-4 - COMP Cams Xtreme Energy Camshafts - Overview - SummitRacing.com
motor is completely assembled now and just need a day off to drop it in which is most likely this friday
Old Nov 22, 2010 | 06:13 PM
RapidRuss's Avatar
RapidRuss
Ok I was just seeing what the lift was..and you should be ok...I think the rule of thumb is like .575" lift on stock non adjustable valvetrain as I recall.. If there in good shape..Good luck...Looks like a fun build...
Old Nov 22, 2010 | 06:28 PM
73 ford guy
you went with roller rockers on your build? What is the real advantage of it? can you expect more horsepower and on a build like mine what would you expect to increase. I found these on ebay which look like a good deal?? would you have to set every valve or is it non adjustable simple bolt on??
BBF SHAFT MOUNT ROLLER ROCKERS FORD FE 352 390 427 428 - eBay (item 300463693859 end time Dec-03-10 01:33:07 PST)
firsttofight11b
38
Sep 25, 2017 10:53 AM
ford-power-f250
Dec 30, 2012 07:45 PM
redneck hillbilly
25
Dec 16, 2008 08:10 AM
66_in_ky
Oct 24, 2008 07:29 PM
76 F150 Ranger XLT
Sep 5, 2004 10:08 PM
