INCREASING BOOST 7.3
Old Nov 8, 2010 | 10:25 PM
NAVYSNIPER's Avatar
NAVYSNIPER
Yes I'm back again, just installed triple gauge set-up on my 2001 F-250 my question is what should my boost be ? If i'm on highway at 1600 rpm's my boost gauge shows 2-5 lbs unless I get on it at 2000 rpm boost raises to 6-8. Best I got after going into passing gear @ 20 lbs, at normal city driving gauge shows 2-3 lbs all the time. Waitng for cold air induction and tuner to arrive from wholesaler. I read on some threads here about shortning the wastegate rod is that something I could do ? I'm a newbie to diesel's and I've been reading as much as I can here on this site. I must say this web site is excellent and the people who have responded to my questions have been very polite and informative. Once again I will THANK YOU ALL for your help. NAVYSNIPER
Old Nov 8, 2010 | 10:44 PM
big poppa's Avatar
big poppa
Welcome back NS. Your boost sounds normal at your cruising speeds. Some people do shorten their wastegate rods but IMO your not going to see any seat of the pants power gains. What kind of tunes did you go with???
Old Nov 9, 2010 | 03:48 PM
NAVYSNIPER's Avatar
NAVYSNIPER
GOING WITH THE DIABLO PREDITOR FOR RIGHT NOW , PLAN ON GOING TO DP TUNER WHEN THINGS GET A LITTLE BETTER $$$$ WAS INVOLVED IN A TT ROLLOVER STILL HAVING SOME ISSUES. JUST WANTED TO GET SOMETHING TO GET STARTED WITH AND GAIN SOME SORT OF POWER INCREASE, THANKS FOR YOUR RESPONSE
Old Nov 9, 2010 | 04:12 PM
robs01f250's Avatar
robs01f250
just unplug your wastegate and attach it to one of the bolts on the IC pipes. You will see 2-3 more lbs of boost
Ken99F350dually7.3
16
Oct 25, 2019 06:23 PM
kegomatix
Apr 20, 2017 07:31 PM
StanleyZ
6.7L Power Stroke Diesel
22
Aug 28, 2016 12:35 PM
blueoval4
Feb 21, 2016 06:56 PM
Tugly
31
Nov 11, 2014 05:44 PM
