Kick down linkage
Old Nov 8, 2010 | 05:16 PM
dean1977's Avatar
dean1977
Kick down linkage
Can anyone tell me how to remove the kickdown lever on the transmission to shift gears?
PLEASE HELP, if possible send diagrams
Old Nov 8, 2010 | 05:23 PM
bashby's Avatar
bashby
Different transmissions have different linkages, do you know what trans you have? If not tellus what truck you're working on and describe where the linkage hooks to the trans and wich side its on
Old Nov 8, 2010 | 05:29 PM
dean1977's Avatar
dean1977
I think it might C-4 its on an 86-F-150
Old Nov 8, 2010 | 05:32 PM
dean1977's Avatar
dean1977
Another possiblility is the T-10
Old Nov 8, 2010 | 05:36 PM
bashby's Avatar
bashby
I think the c4 is the same as my c6, it just has an E clip that holds the kickdown linkage on, are you talking about the shifter linkage? (the one that selects P R N D...) that one just ppops loose, it has a ball socket joint. You need to pry pretty hard to pop it loose.
Old Nov 8, 2010 | 05:49 PM
dean1977's Avatar
dean1977
is this the part on the transmission it self
Old Nov 8, 2010 | 06:07 PM
bashby's Avatar
bashby
I'm not sure what you mean here. Maybe if you tell us exactly what you're trying to accomplish it would help.
Old Nov 8, 2010 | 06:40 PM
dean1977's Avatar
dean1977
I need to replace the peice on the tranny that shifts the tranny into gear. The link below is easy to see it is the chrome peice on the tranny located by the white sticker.
Ford Automatic Transmission | Rod & Custom Magazine Article at Automotive.com
Old Nov 8, 2010 | 08:05 PM
86351wProject's Avatar
86351wProject
The tranny in the pic is a C4. The C6 is similar.
There are 2 levers.
The one on the outside should be the kickdown. it is held on with a small C clip that easily pops of with a small screwdriver.
The inside lever is the main shift lever wich is tied to the linkage that goes up the firewall and into the column shifter. This lever is pressed onto the shaft.
Old Nov 8, 2010 | 08:13 PM
dean1977's Avatar
dean1977
Do you know how difficult the inside lever is to replace?
Old Nov 8, 2010 | 09:44 PM
86351wProject
Honestly I dont.
Old Nov 9, 2010 | 05:00 AM
Greyf100's Avatar
Greyf100
drop the pan, filter, and valve body....pretty much take the bottom part of trans apart. Be careful of all the tiny pieces and parts, and remember where everything goes.
Old Nov 9, 2010 | 06:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Borg Warner T-10 4 speed manual = 1961/65 Passenger Cars only.
Your "About Me" profile says: 1984 F150: Depending on the application, could have a C5 (11 trans pan bolt holes); AOD (14 trans pan bolt holes); C6 (17 trans pan bolt holes).
Therer are two levers outside the case. Manual control lever & Kickdown lever. These parts are specific to each trans type and to the year of the vehicle.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
